Is there an easier way of testing the speedo sensor other than whats in the Haynes manual? (AA batteries and resistor)
Perhaps with a multimeter etc? |
The speedo doesn`t work.
Wanted to test the sensor before buying another one, then finding out its something else. |
#4 | |
I looked at the K3 pointy manual on page 8-38 (Inspection of the speed sensor) and it describes the test method. Its a hall effect magnetic sensor and cant be measured just by connecting a multi-meter to the wires. The batteries are to provide voltage to the circuit when you have the speed sensor disconnected from the wiring loom, you may find it easier with a 9V battery as its easier to connect and wont go rolling around the floor. When its rigged up you should spin the wheel slowly and see the voltage measured vary from 0v and whatever voltage battery you use e.g. 9v. If thats working then the sensor may well be fine. Check for obvious damage though by removing the front wheel, the little lugs tend to get chewed off preventing the rotor from rotating properly. If you can get one, far easier to just plug in another speedo and spin the wheel. Make sure that you actually have power to the speedo unit (are the warning lights coming on etc) otherwise nothing will work. Other things to check are obvious poor connections, particularly where the speedo connects to the loom, give that a squirt of WD40. And of course take a look at the fuses and make sure they are all intact, especially the one for the signal circuit as this powers the speedo unit on the later models. Last edited by flymo; 02-04-08 at 08:15 AM. |
Thanks Flymo.
Its the wifes bike, 2001 curvy. One thing i didn`t know is that fuse you mentioned. I have to remove the front wheel etc to clean up the grotty looking forks, so will have a look at the rotor etc over the weekend. All the warning lights and the lights that illuminate the clocks are working fine. Last edited by rf9rider; 03-04-08 at 03:53 AM. |
Rotor inside the sensor was in about 1000 pieces.
Problem solved hopefully, ordered a new one. Thanks for your help. |
speedo sensor | Apophes | SV Talk, Tuning & Tweaking | 2 | 30-01-08 09:25 AM |
Speedo sensor. | phil24_7 | Stuff Wanted | 4 | 06-01-08 01:56 AM |
Speedo sensor. | phil24_7 | SV Talk, Tuning & Tweaking | 5 | 19-12-07 08:41 PM |
Speedo sensor | phil24_7 | SV Talk, Tuning & Tweaking | 9 | 09-12-07 09:18 PM |
Speedo Sensor | djt_spurs | Stuff Wanted | 2 | 14-11-07 10:09 AM |
