Old 01-04-08, 11:03 AM   #1
cb5_keith
Default Wash with fairy?
DAFT question...
Washing up liquid? Always used it on my old CB...
Is it generally alright to use?
At least i will have soft hands
Old 01-04-08, 11:06 AM   #2
neio79
Default Re: Wash with fairy?
NO, NO and NO STOP using it, and buy proper stuff. If you now have a Suzuki it will rust as you wash it., Fairy and any washing up liquid has salt in it so rather than washing it off you are putting corrosive stuff back on the bike.
you honda probably survives cos of its build quality. but if ou want the SV to survive do not use it. There are plenty of good bike cleaners to use.
Old 01-04-08, 11:08 AM   #3
G
It also removes protective waxs from paints and oil/grease from areas where you really dont want it to be removed.
It also fades paintwork quite quickly.
Old 01-04-08, 11:08 AM   #4
Alpinestarhero
Neio, does it have salt in it? As in rock salt / NaCl?
Anyway, I think it would be fine - but its best to use proper car/bike wash, the detergents are a bit more powerfull and will remove stubborn grime better.
Not as kind to your hands though
Matt
Old 01-04-08, 11:32 AM   #5
MiniMatt
I'm pretty sure it does, but just had to hunt around to check - Ecover washing up liquid definitely does - they seem to be about the only brand who are willing to 'fess up their ingredients list: http://www.ecover.com/gb/en/Products...s+lemon+UK.htm
Whether the quantities are anything to worry about is a different matter which I can't answer though.
My solution is to allow a protective layer of grime to build up and coat your bike. It's worked for me
Old 01-04-08, 11:35 AM   #6
cb5_keith
Ah i see...hmm i shall i keep the fairy next to the sink then...
What do people use to clean their bikes with? Anything highly recommended? I may pop to j and s and have a look see...
Old 01-04-08, 11:42 AM   #7
plowsie
I use car shampoo, some simple tescos stuff keeps mine fairly protected from all the crap over the last few weeks, I havent cleaned mine in 3 weeks and it still comes up nice. But if your like I normally am, get some HG Gel cleaner, that stuff is awesome and really does a good job. Bitta Autosol on the Metal visible bits and we are away
Old 01-04-08, 11:50 AM   #8
thedonal
I've been using washing up liquid and water for over a year (Fairy or Sainsburys own)- though I do rinse the bike as thoroughly as I clean it.
I have also started using muc-off motorcycle protector afterwards. Does a stunning job, that stuff does. The bike seems to stay clean- even in teh nasty weathers.
Though if it is that bad for the bike, I will use proper shampoo instead. Can't say my paintwork has particularly suffered, though.
Old 01-04-08, 11:53 AM   #9
Dangerous Dave
Get some proper car/bike shampoo, fairy is a big no no!!!
Old 01-04-08, 11:57 AM   #10
pmapp
pmapp's Avatar
Does that mean I should stop using Muc Off on my dishes then?
The Speedhump Fairy the_runt69 Bikes - Talk & Issues 14 20-02-07 10:29 AM
The shortest fairy story ever Stingo Idle Banter 1 01-11-06 02:33 PM
Anyone heard from Fairy Dust? Ed Idle Banter 12 22-02-06 09:35 PM
The oil fairy diamond SV Talk, Tuning & Tweaking 20 13-06-05 12:17 PM
The Speedhump Fairy Manic Racer Idle Banter 4 09-01-70 01:53 PM
