Old 02-04-08, 01:49 AM   #1
ljharmitt
Default Clutch
Since my off where the bike slid down its l/h/s, when its in gear with the clutch in it still pulls forward quite a bit. Any ideas what this could be or how i could fix it?
Doesnt do it in neutral and didnt do it in gear before.
Any help much appreciated
Old 02-04-08, 02:04 AM   #2
MiniMatt
Default Re: Clutch
Probably stating the obvious but might be worth messing around with the adjuster at the lever (locknut and adjuster wheel combo thing) first and if that doesn't do much check the clutch release gubbins behind the front sprocket cover for signs of manglement.
First step anyway, I'll think of something more technical when I've finally gotten some sleep
Old 10-04-08, 11:22 PM   #3
ljharmitt
Default Re: Clutch
Checked both, thanks for advice but both seem fine any more ideas?
Old 11-04-08, 01:13 AM   #4
Default Re: Clutch
Search for sid squids post on clutch adjustment and do that
Old 11-04-08, 07:23 AM   #5
Alpinestarhero
Default Re: Clutch
Does it only drag when cold, or drag all the time? I suspect the clutch needs some serious adjustment, both on the cable and worm-drive doo da.
At cold, the clutch can drag a little bit and make the bike pull forward a teeny bit until the oil is warm, when you are in first with the clutch right in
Matt
Old 11-04-08, 07:32 AM   #6
Viney
Default Re: Clutch
Already said. Search for a post on Clutch adjustment by SidSquid
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
clutch kit sv650nutter149 For Sale - SV's and SV related items 0 25-06-07 03:08 PM
clutch has had it! socommk23 SV Talk, Tuning & Tweaking 8 10-03-06 06:21 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
