Old 07-04-08, 05:44 PM   #1
SV-net
Default tyre Valve Change?
Can my valves be changed without removing the wheel from the bike.
Mine are both seized on (metal stems and metal caps) and I need to get them both replaced. Or do they need to remove the wheels to break the bead on the tyre?
Is there not a possible way to do this quicker and easier?
Old 07-04-08, 06:15 PM   #2
Blue_SV650S
Default Re: tyre Valve Change?
Nope, you will need to get the tyre off dude!
Old 07-04-08, 08:44 PM   #3
BILLY
Try some penitrating fluid first to see if you can get the dust caps off!
Old 07-04-08, 08:50 PM   #4
SV-net
No fluid will budge em. Somebody did suggest a Dremmel!! Will see if I can borroe one. If not then wheels out and down the shop I guess.
Old 08-04-08, 10:44 AM   #5
Mogs
Have you tried heating the caps up.
Old 08-04-08, 10:48 AM   #6
Biker_Billy
If they are metal, and you are careful - can you use some molegrips on the valve stem, and some on the valve cap and try to twist it loose?
Be careful tho, and if you get it free, I would suggest using some water too see if you have dislodged the valve and see if you can see any air bubbles from leaks...
I would replace them with plastic, or make sure you take them off every week to make sure they dont get stuck again (btw - how long since you last checked your tyre pressures?)
HTH,
BB.
Old 08-04-08, 10:48 AM   #7
Flamin_Squirrel
Fire will fix it
Old 08-04-08, 10:49 AM   #8
Biker_Billy
You may as well have a go and try to get them free - if you do knacker the valves, you will only have to go to the tyre place anyway...
Not sure how a dremel will free them - how was it suggested to be used?
Old 08-04-08, 11:00 AM   #9
21QUEST
21QUEST's Avatar
I'm assumming it's one of those metal ones.I had a siezed one some time ago. Those things really need a bit of grease to stop them siezing or every so often undoing.
Plent of penetrating fluid, molegrips with a bit of rag around the lowers section to stop it twisting and pliers on the cap it's self.
Re dremel, I guess you could try cutting the top of the cap off and then some penetrating fluid.
Ben
Nemo me impune lacessit.
Old 08-04-08, 12:07 PM   #10
Grind off the side of the cap to break the tension then get it off.
Valve change & tappet (shim) check. rictus01 SV Talk, Tuning & Tweaking 10 08-11-10 12:39 PM
tyre valve just blow out PJinUK SV Talk, Tuning & Tweaking 7 08-06-08 06:07 PM
How not to change a tyre Stu Bikes - Talk & Issues 32 06-06-07 11:19 PM
Help!!! Tyre valve has gone awry... Bluesteel SV Talk, Tuning & Tweaking 13 20-04-07 02:16 PM
Front tyre change The Mass Tyres 1 05-08-05 10:09 AM
