Old 15-04-08, 11:13 AM   #1
Grinch
Lightbulb Clutch 'Selection' Problems.
In the continuing saga that is my SV we have the next instalment.
I've had a bit of a look about and found a few things that I have read on the subject but nothing that really nails my needs about it down. So heres my thoughts and I would love to hear some people opinion on them.
Now, my clutch sometimes has trouble selecting, in that I have to fight with the select to get a gear or neutral. Now I'm using some oil from Hein Gerike which I seem to be noticing more clutch slip, but could it also be that this is causing my selection problems. I thought it was my rather stretched clutch cable and worn worm drive, but while replacing these have made a different in a lighter clutch the problem is still there. So I was thinking that I have just under a 1000 miles till my next oil change so I might just swap this out asap, or while I still have the problem I have a spare clutch basket that I could drop in (its about 30K old while this one is a 60k'er). Though this is not something I have done before so I'm not sure the tools that I will need, so will need to look this up unless someone knows off hand...
Thanks.
Old 15-04-08, 11:42 AM   #2
Default Re: Clutch 'Selection' Problems.
If the clutch is lifting but still dragging it points to the clutch basket being worn. You can just see by looking in the oil filler sometimes.
It isn't the only possible fault, but considering your mileage it's quite likely.
Old 15-04-08, 11:47 AM   #3
Grinch
Would you be surprised if I said, huh?
Old 15-04-08, 12:39 PM   #4
jambo
jambo's Avatar
What Sid Squid is saying is that the clutch plates have tabs on the outer edge of the friction plates. These lock into the tabs in the clutch basket. The surface of these tabs on the clutch basket should be smooth meaning the clutch plates can slide along the basket tabs as you pull the lever in and out. This lets the plates separate and thus stop driving the rear wheel.
However, these tabs on the clutch basket get worn by the movement of the clutch friction plates putting notches in them, it is then possible for them to stick in these grooves not fully engaging / disengaging.
Open the oil filler cap and you should be able to see the clutch basket and see if it's notched badly, otherwise, taking the clutch cover off, and the clutch plates out will give you a very good view.
Jambo
Old 15-04-08, 12:44 PM   #5
jambo
jambo's Avatar
A Picture speaks a thousand words:
http://fiche.ronayers.com/Index.cfm/...7/Group/CLUTCH
Part 1 is the clutch basket, which part 7 (the clutch friction plates) lock into. This is the part that wears. Part 3 is the hub which the steel plates (part 8 ) lock onto.
Jambo
Old 15-04-08, 01:14 PM   #6
oldie
Not sure about the SV650 specifically, but most bikes I've worked on, you could usually improve a worn clutch basket by filing the wear notches out of the grooves, and also any burrs on the tangs..
Old 15-04-08, 01:22 PM   #7
jambo
jambo's Avatar
You can certainly do this, but if there's a good nick one going spare, and this does turn out to be the problem (not checked yet), then I'd be inclined just to swap it out. Filing it will probably allow it to work properly, but as I've been told several times, wear breeds wear, and you'll only be back in there again at some point....
Jambo
Old 15-04-08, 02:10 PM   #8
Grinch
Cool, this is now all clear, cheers. I'll be having a peek later then.
Old 15-04-08, 02:42 PM   #9
Jambo
But it saves you paying out for a while, and it's dead easy to get to the clutch.
Old 15-04-08, 02:45 PM   #10
jambo
jambo's Avatar
Very true, but he's pointed out he has a spare one....
Clutch problems. otacon88 SV Talk, Tuning & Tweaking 13 16-05-09 06:19 AM
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
Gear selection problems Stingo SV Talk, Tuning & Tweaking 8 04-09-08 05:10 PM
Clutch problems? PWNDLOL SV Talk, Tuning & Tweaking 1 05-07-06 07:10 AM
Gear Selection Problems Iansv SV Talk, Tuning & Tweaking 14 12-01-06 03:14 PM
