Old 16-04-08, 05:29 PM   #1
999nutta
Unhappy problems after oil change
Today I flushed the engine and replaced oil and filter.
Now before i did this gear selection was fine.
now i have problems engaging 2nd from 1st or neutral from 2nd or neutral at all. if i turn the engine off finds neutral fine. has also been jumping up through the gears as well.
not too sure why this has happened but the gear lever feels solid.
clutch and all has been checked.
any ideas??
Old 16-04-08, 05:31 PM   #2
sv650k4
Default Re: problems after oil change
i take it you havent had any of the gear pedal set-up off or anything?
Old 16-04-08, 05:34 PM   #3
999nutta
no. its not been touched. If the bike is started in first it feels like its trying to creep, which is why checked clutch but alls fine
Old 16-04-08, 05:39 PM   #4
DoubleD
Check that your oil level is good, I have seen this affect the gear selecting.
I have just changed my oil and I put to much in (must wait for oil to settle before adding more) this caused the creeping you said about on mine. Drained some off and all is well now.
HTH
Old 16-04-08, 05:41 PM   #5
tomaso
I'd agree with DoubleD. Too much oil and the clutch drags and gear / neutral selection can be difficult
Old 16-04-08, 05:42 PM   #6
Alpinestarhero
Yea, sounds like over-filling of oil. Likewise, things can get a bit notchy if theres a bit less oil than there should be.
Check the oil levels, if its too much, then I assume all you have to do is un-nip the sump plug and let the oil trickle out, watching the level as you go? might need a mate to help though?
Matt
Old 16-04-08, 05:46 PM   #7
999nutta
checked the oil levels. pretty sure its just under the maximum line. just can't think what else would cause it. Just hope it wasn't the engine flush
Old 16-04-08, 05:49 PM   #8
DoubleD
if it is to much oil then just open the sump plug and drain some out, have a rag handy as the oil just goes everywhere when you try and put the plug back in while it is still draining..... trust me on this
Old 16-04-08, 05:50 PM   #9
DoubleD
did you use the correct oil?
10w/40 motor bike oil for a pointy not sure if the curvy is the same.
Old 16-04-08, 05:53 PM   #10
sv650k4
my bike is at the L line and its fine and all good loosen the sump nut slightly and let a we bit run out see if its any different.
Spend £117 & change on bike - but no change in bike pete m Bikes - Talk & Issues 10 06-05-09 12:26 PM
Problems with the org :( plowsie Idle Banter 0 13-04-07 02:54 AM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Gear change problems rubbermonkey SV Talk, Tuning & Tweaking 1 25-12-05 04:32 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
