Done a search but cant find much info. Changing the bearings in my 1999 650 and had a look at the manual. Says you need a special tool to remove them, so what will i have in my garage that will do the job? Any other tips would be greatly apptriciated. Cheers.
i would normally use a big screwdriver 2 get the old ones out.
Long screwdriver and a hammer.
Be carefull drifting the old bearings out, tapping around the whole circumference of the bearing, don't concentrate on one spot or you can damage the wheel. |
I use my nice stainless Bahco punch. Or a big screwdriver, depending on what comes to hand first
Thanks for all the advice, i'll give it a go. Cheers.
I find that an extension bar from a typical socket set is good for this. Not as sharp and severe as a screwdriver.
Gently does it, doesnt need massive taps. Prop the wheel just off the floor/bench with some wood and tap away. Tune in next weekend to get tips on how to put the new ones in ![]() |
#7 | |
Can we have that "how to" before monday week plz ![]() ![]() |
I use a 3" wood dowel to drive the bearings in, it is soft and will not mar or otherwise harm the new bearing. I have used the same piece for years, just cut it off square when it gets bunged up. It was a handle for an adze when i bought it, cut it into several pieces for different size bearings, it went from 2" to 5" diameter along the length so works even for truck rear ends with one chunk or another.
I also see a lot of people using a socket reversed on an extension for this, pretty much duplicates a bearing driver. Be careful when using a steel implement. |
#9 |
Good morning all.
I have seen plenty of wheels that have been ruined when the uninitiated try to change bearings. My preferred method for removing the old ones is a long drift, despite having 'blind' hole pullers & slide hammers etc. The centre of most wheels is either tapered, or has a shoulder on one side, therefore the spacer will dislodge on one side only. If you have a grinder or a belt sander to hand, evenly reduce the diameter, & the of one of the old bearings until it drops straight into the wheel then reduce the thickness of the centre of the bearing slightly, you then have the perfect bearing drift for installing the new ones. Remember to tap on the outside edge only. When installing new bearings I always heat the wheel gently, & lightly oil the outside of the bearings. Do not wallop the new bearings in too tightly so that they are hard up against the spacer. You normally find that on most wheels one bearing goes against a shoulder & the other doesn't. Install the one against the shoulder first, drop in the spacer & then carefully drift the other bearing in until it's just touching the spacer, but you still have a little lateral movement of the spacer. Pass the spindle through to align everything & check that the lateral movement of the spacer is still the same. If it has gone a little floppy (MATRON) drift the bearing in a minute fraction more. If using an old bearing as a drift you can have the spindle in situ as you're doing it, this really helps to keep everything in line. Cheers. |
#10 |
Quick Q , managed to get my left hand side bearing out, and of course the spacer dropped out easily enough, however the right hand side is not moving an inch for me, am i actually missing something here should it not be the same situation, punch down and drive out, and yes i've made sure i'm not punching the small internal lip..
Rear Wheel Bearings | gavinsky23 | SV Talk, Tuning & Tweaking | 0 | 28-05-08 01:09 PM |
1200 Bandit FRONT wheel bearings | Blue_SV650S | SV Talk, Tuning & Tweaking | 3 | 15-02-08 09:22 AM |
wheel bearings | mart | SV Talk, Tuning & Tweaking | 1 | 21-05-06 05:14 PM |
Front wheel bearings - £50 fitted at Hamilton MC | Dirty Baz | SV Ecosse | 6 | 31-01-06 10:47 PM |
Wheel bearings | manxsv | SV Talk, Tuning & Tweaking | 15 | 09-12-05 04:51 PM |
