Old 18-04-08, 01:03 PM   #1
Baph
Default Extra lights & the law/MOT?
OK, as I now & again work nights, I find myself wanting the ability to see around corners at nights.
The easiest solution I can think of is spot lights, wired to the main beam switch.
I know I'd have to get ones marked for the road, and relevant EU/BS stamps etc. But my question is, does anyone know of anything else I'll have to look out for? Doubfut, but any potential issues with MOT for having spot lights fitted to a bike?
Old 18-04-08, 01:05 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Extra lights & the law/MOT?
See loads of GS riders with these added - cos obviously it gets VERY dark in London.......
Dont see why it would be a problem if properly adjusted.
Old 18-04-08, 01:09 PM   #3
Baph
That's the thing see, I want to see around corners. So they'd be aimed low, but rather bright, and wide (leaving the bike stock lights looking forwards more).
They'd also only be on with main beam, not dipped.
Old 18-04-08, 02:19 PM   #4
Dangerous Dave
Shouldn't be a problem, as long as all the lights and lens arre 'BS' or 'E' marked and fully working at MOT time then I can't see any major problems. The golden rule about lights at MOT time is if they are fitted then they must work.
PS, let us know how you get on with the mod please.
Old 19-04-08, 10:56 AM   #5
Baph
Just to bump this thread
Does anyone know a cheap place to order Hella lights from in the UK (so far all I can see is US ordering)? I'm looking at the Hella Optilux 2500 Angel Eyes, as they seem perfect for the job.
I'm also intending on tinkering with the Angel Eyes surround (LEDs) - more detail on that later. I'll also be wiring it up so that I have to flick a switch to enable the additional lights, and THEN they work on the main beam switch.
Basically, flick the dash switch, the LED surrounds will come on, push main beam, and you get main beam plus Hella 2500's (12v/55w fog lights apparently).
Old 19-04-08, 07:25 PM   #6
fatneck
Sounds cool, gonna wanna see some pics of those bad boy Angel Eyes
Old 20-04-08, 12:06 AM   #7
Scoobylou
As married to a mot tester.. I can tell you that the spot lights would not be a testable item..and yes he does test bikes too...
Old 20-04-08, 06:22 AM   #8
Red Herring
Red Herring's Avatar
I've got a fair bit of experience rallying on bikes. some of which involves blatting up country lanes in the middle of the night. I used to run two additional lights mounted either side about knee height (about where the spots are on a GS) and then set the beams high and to cross over. This way they illuminated the road ahead and to either side when hard on the brakes (Critical to see the turn in point) and then once in the bend the "upper" or "outside" lamp would continue to shine around the corner so you could see where you were going.
The choice of lamp is critical. Many car lamps have a flat beam spread which is no use at all, and driving lamps tend to have a narrow pencil beam which is fine of it happens to be pointing in the right direction, but there are so many variables with bikes it rarely is. The best lamps have a broad even spread of light, you don't need huge penetration, just a good spread so fog lamps, with an appropriate bulb, are a good place to start.
Old 21-04-08, 06:15 AM   #9
Baph
Fantastic. Just found a cheap source for the Angel Eyes Shall be buying come pay day
Originally Posted by Red Herring View Post
... stuff about positioning of lamps...
Good news on the fog light aspect (as that's what I'll be buying)
As for positioning, on the pointy SV, I'm looking at taking the black lower half off the bikini fairing off and drilling holes in that. My first thinking was under the bottom of it, which would allow for rotation on the horizontal access. But I'm also considering the diagonal piece would would put both lights crossing each other naturally, with adjustment in the vertical axis.
I'll post back when the mod is done, with night time pics too.
Old 21-04-08, 06:24 AM   #10
SoulKiss
SoulKiss's Avatar
Personally I would clamp them as high up the forks as possible- with having RWU forks this would mean they would always be at the same height/level as when set, so zero chance of accidentally blinding someone (although as you have stated, these are to be wired into high-beam only, so less chance of that - unless when using the pass light)
Extra Large Blue_SV650S Idle Banter 53 15-08-07 06:31 PM
little extra power for 650 sv bobsere SV Talk, Tuning & Tweaking 22 30-07-06 10:04 AM
extra value meal Wiltshire7 Exhausts 14 19-12-04 02:54 PM
Extra Security ? Warren Bikes - Talk & Issues 21 02-11-04 10:57 PM
