Old 18-04-08, 07:44 PM   #1
Rich
Rich's Avatar
Default Speed Bleeding!
Just bled brakes for the first time and from what i've heard it can be a pig. So i got a couple of speed bleed nipples and they're bloody great, lets the fluid through and doesn't let any air in. So if you need some new nips give these a try
That is all!!!
http://www.demon-tweeks.co.uk/produc...ode=GDRBN704SB
RIP Hovis - Unlucky Boyo
Old 18-04-08, 08:03 PM   #2
rictus01
rictus01's Avatar
Default Re: Speed Bleeding!!
I got a spanner, bit of tube and a jam jar, works fine, but hey people tell me it's a problem, so if it works for you
Cheers Mark.
Old 18-04-08, 08:49 PM   #3
DoubleD
Cheers Mark.
+1 on the tube and coffee jar, works just fine.
Old 19-04-08, 07:23 AM   #4
ThEGr33k
Cheers Mark.
+2
I think im a master bleeder now. I bled the clutch about a thousand times, I kid you not thinking that the clutch was dragging and causing problems.... turned out it was the gear selecter arm that needed greasing... Sigh.
At least im a good bleeder now.
Old 19-04-08, 01:19 PM   #5
I can do it with just a tube, but I'm miles faster with the big syringe and they're dead cheap, so it's worth it I reckon.
Old 19-04-08, 06:09 PM   #6
I use a spanner, that's it. Why complicate matters?
Old 19-04-08, 07:17 PM   #7
ThEGr33k
Old 19-04-08, 07:19 PM   #8
Why the shock? Nowt wrong with my brakes.
Old 19-04-08, 09:04 PM   #9
Davido
Only a spanner here too. Just clean all the excess fluid and you're away.
It doesn't start to bubble paint until its been on there a good few hoursanyway.
Old 19-04-08, 11:53 PM   #10
ThEGr33k
Nothing wrong with it... just you get oil all over the floor etc and it just cant be as easy I wouldn't have thought.
But whatever.
bleeding clutch! jimmy__riddle Bikes - Talk & Issues 4 24-07-08 08:11 AM
bleeding thing Taylor1975 SV Talk, Tuning & Tweaking 8 17-03-08 10:14 AM
Bleeding Brakes - Again HopefullySoon SV Talk, Tuning & Tweaking 2 28-08-07 09:13 AM
Bleeding breaks sweepdoggydog Bikes - Talk & Issues 4 03-11-06 07:49 PM
Bleeding Brakes (Bleeding Kits) 21QUEST SV Talk, Tuning & Tweaking 8 20-06-06 05:31 PM
