Old 19-04-08, 11:10 PM   #1
younggunns
Default chicken wire in lower fairing holes...?
well not exactly chicken wire but i believe i could get the correct grating down my local car shop, i would use the sheet grille with holes.
i am gonna cut to size to fit lower fairing holes but am really stuck with how to fix it to the back of the fairing,
as i don't have a plastic welder or know anyone that does i was wondering how i could achieve this.... i have seen many designs of the grille i could use.
please give me some tips to installing these as i am stuck.....
thanx guys...
lee...
Old 20-04-08, 07:08 AM   #2
flymo
flymo's Avatar
Default Re: chicken wire in lower fairing holes...?
thanx guys...
lee...
You could buy yourself a cheap glue gun for less than a tenner. Or use Araldite.
Old 20-04-08, 08:32 AM   #3
Davido
I've done that, I used some fire grate from B&Q. Nice gold stuff it was, I'll see if I can get a pic.
Oh and as said, use a hot glue gun and just bend the grate around the holes to get the shape right.
Old 20-04-08, 09:55 AM   #4
Dangerous Dave
Glue gun, very cheap to buy, or get a fibre glass kit (?5) and use the 2 part bonding liquid.
The glue would be the easiest to do and easier to remove/replace at a later date if required.
Old 20-04-08, 04:49 PM   #5
Bad Intentionz
I used a soldering gun and melted it into the back of the fairing. looked real nice once finished, till the laquer my mate sprayed started flaking. had to take it out as it began rusting. gonna do it again soon but do everything myself. that way i'll take more care!
Old 20-04-08, 05:01 PM   #6
younggunns
i do have a glue gun with the sticks that came with it.
are the sticks ok to use in all weathers and should i lightly sand the fairing,
i have a rough idea of what to do i just wanted some ideas to help me along the way.
cheers guys.
lee..
Old 20-04-08, 05:09 PM   #7
sv650k4
i think i would use the glue gun if i was in the same postion as you.
Old 21-04-08, 11:49 AM   #8
Dangerous Dave
Yeap, glue gun is ok for all weathers. Sand down the panel inner just a little and make sure the surface is clean and dry for the best adhesion.
k6 lower fairing gralln9 Stuff Wanted 0 04-08-08 03:20 AM
Lower Fairing for K6 metalmonkey Stuff Wanted 4 03-07-08 04:53 PM
Mesh for meshing-in the holes in fairing Jase22 SV Talk, Tuning & Tweaking 15 26-02-07 05:32 PM
Lower Fairing? Rangerman SV Talk, Tuning & Tweaking 9 24-09-06 09:11 PM
Lower fairing inlet scoop screw & top fairing clip Mr. Marcus Stuff Wanted 2 05-12-05 09:18 PM
