Old 24-04-08, 07:11 AM   #1
krhall
Default Rear Brakes, Disc and Pad Replacement - Can I?
Well basically I'm rubbish at DIY, but the more I achieve the more I want to try. I need a new rear disc and rear pads (desperately) and am wondering whether or not this is a step too far for me?
How difficult is it?
.....and are there any simple (really simple) 'Rear Brakes for Dummies' type instructions?
Also what tools would I need?
Old 24-04-08, 07:34 AM   #2
Baph
Default Re: Rear Brakes, Disc and Pad Replacement - Can I?
Pads - pish easy so long as the piston goes back into the caliper nicely (plenty of info on the org already). Tools required, a couple of sockets (I forget the sizes). Maybe a torque wrench to put them back on, but I just guess the tension of the bolts on the rear (front takes more braking force).
Discs - a little more complex, but certainly do-able. Wheel will need to come off for this one, then there's a couple of bolts holting the disc to the wheel itself. I'd be a little more cautious about torque on this one, spinning disc and all.
Old 24-04-08, 11:19 AM   #3
sv650k4
the pads are pretty easy as baph says and as for the disc the hardest part ther is probley just taking the wheel off lol the disc is only held on with a few bolts.
Old 25-04-08, 09:56 AM   #4
krhall
A friend of mine has offered to oversee my work and advise, he has been doing his own bikes for years, so I feel safer having a go now, plus he has every conceivable tool possible.
On another note, I called EC Bate (Dartford) to get a quote for the parts they quoted me EBC disc "as it is much cheaper than Suzuki" it was £97.52, so assuming they were doing me a favour I didn't ask about the Suzuki part.
My friend called Aye Gees, who I don't think much of, and got prices from them. A proper Suzuki read disc is £70 (all-in). WTF? That is the last time I go anywhere near ECBate!!!!
So the disc and pads are on order and I will hopefully be fitting sometime in the coming week. Thanks all for the advice.
Old 25-04-08, 10:51 AM   #5
muffles
Maybe they quoted you a price for a front disc by accident, lol - I think that's a decent price for a front. Although I've never bought one so never studied it in detail!
Old 26-04-08, 06:37 AM   #6
petevtwin650
Shame, you could have got a braking wave disc for the same sort of money.
Use only a good quality allen type socket when removing the disc bolts as they are loctited in from the factory and are very tight, so you run the risk of b*ggering up the bolts if an inferior tool is used.
Old 26-04-08, 07:23 AM   #7
Davido
Also remove the reservior lid off your master to stop your caliper pistons moving back in. (only necessary if you've got a lot of fluid in there)
Old 26-04-08, 08:56 PM   #8
Stingo
Stingo's Avatar
Here's my thread when I did my back brake last year...might help...
http://forums.sv650.org/showthread.p...ght=brake+pads
Twitter: @poseidon_ashore
Old 27-04-08, 12:13 PM   #9
dirtydog
Knob faced knobster
dirtydog's Avatar
Nah front discs are abouit £140 each
2001 SV650 in shimmerin green, Not broken anymore
Old 28-04-08, 11:27 AM   #10
muffles
Is that for EBC or OEM front discs? It makes sense if OEM are £140 each
Replacement brake disc - different size? mikebrooman SV Talk, Tuning & Tweaking 21 04-03-09 01:55 AM
Anyone need a rear disc? eviltwin Idle Banter 0 31-01-09 11:08 AM
rear disc diameter noob-saibot SV Talk, Tuning & Tweaking 17 10-10-08 10:32 AM
Really hot rear brake disc Warthog SV Talk, Tuning & Tweaking 19 24-07-08 01:32 PM
Front Disc Replacement? ryancor SV Talk, Tuning & Tweaking 12 04-04-06 03:44 PM
