Old 25-04-08, 11:46 AM   #1
mattglavin
Default rear brake caliper pins
Has anyone got a tip on how to remove the brake pad pins which are siezed solid in the holes.
I have heard about drilling holes but am a bit nervous about getting that wrong.
Old 25-04-08, 11:49 AM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: rear brake caliper pins
If they're really stuck then you may end up drilling them out, i've had to do it on about 3 rear calipers so far.
I've tried locking pliers and all sorts to get them ouy but to no avail in the past. I now have very well greased stainless steel pins
2011 Speed Triple 1050
Old 25-04-08, 11:50 AM   #3
Grinch
Yep, drill a hole behind the pins, then whack it real hard. Had to do it with my front pins the other week.
The advantage is, once the hole is there, its all ready for the next time. Though don't make the hole bigger then the pin.
Old 25-04-08, 11:50 AM   #4
sv650k4
i had the same problem on one of my bikes before i ended up just buying a different caliper.
Old 25-04-08, 11:53 AM   #5
mattglavin
What did you whack it through with, did you use the drill bit ?
Old 25-04-08, 11:56 AM   #6
Grinch
A old alen key that I had turned into a I from a L.
Old 25-04-08, 12:55 PM   #7
Hooligan
I split my rear caliper in half by loosening the bolts, then i was left with the seixed pins which i could get hold off. Other way it to drill holw and tap them through.
Ive got spare pins for sale if you need them.
Old 21-04-09, 07:03 AM   #8
lazymanc
Do a search for "caliper rebuild" on the forum, there are a couple of threads from people with similar issues. General advice seems to be to use heat (blowtorch) and shock therapy to loosen it.
lazymanc is offline   Reply With Quote
Old 21-04-09, 07:22 AM   #9
Dave20046
Dave20046's Avatar
I used a hammer, wurth penetrant, heat, an awl (?), and mole grips.
Old 21-04-09, 07:29 AM   #10
husky03
split the caliper and get the pin in a vice, turn the caliper and you'll free te pins without having to drill.
rear brake pins siezed - what now ejohnh SV Talk, Tuning & Tweaking 31 15-12-08 01:16 PM
removing the rear brake pins emcf SV Talk, Tuning & Tweaking 6 20-10-07 06:59 AM
Rear brake pins Viney Stuff Wanted 4 29-08-06 07:29 PM
Brake caliper 'pins' ? pepe SV Talk, Tuning & Tweaking 7 18-05-06 11:47 AM
rear brake pins syphonus SV Talk, Tuning & Tweaking 9 11-10-04 09:40 PM
