Old 25-04-08, 09:27 PM   #1
sv_rider1990
Question To much back firing how do i solve it?? :S:S:S
Right heres the situation my bikes been fine just fitted ne chain, sprockets, just had a service etc so it should all be running well... well ive got a Scorpian Titanium slip on can and a BMC air filter and also Irridium plugs fitted and it has been running fine howver just of late most noticably after the above mentioned its started backfiring a hell of a lot more and im not a weekend rider i commute 5 days a week so i keep the baffle in to save my ears and to avoid constant headaches lol??
The mixtures fine checked the plugs there perfect anyone got any pointers???
Old 25-04-08, 09:34 PM   #2
Stig
Default Re: To much back firing how do i solve it?? :S:S:S
Balance your carbs.
Old 25-04-08, 09:45 PM   #3
also, check the carb hoses, I recently had one with a small split on the end of one. I quite like the extra noise on slowing down, but it got a tad annoying. Don't know owt about carbs..don't know which one it was, just know it were the one you stick your balancers on.
Old 26-04-08, 06:32 AM   #4
petevtwin650
Sounds like either the one that goes to the vacuum fuel tap Dizzy which is from the rear carb or the little cap that goes over the front vacuum takeoff.
Old 26-04-08, 10:33 AM   #5
sv_rider1990
I'll take a look at the carb hoses etc. Does backfiring damage anything like the engine or is it just an annoying noise?
Thanks for the replies!
Old 26-04-08, 02:54 PM   #6
sv_rider1990
Not the hoses checked them all out. I'll take a look at my airfilter see if that needs a clean or whatever might work lol.
Old 26-04-08, 03:30 PM   #7
rallyjon
Backfiring is normally an ignition fault caused by an erratic spark (not firing at correct time) thus igniting the fuel in cylinder as the valves open.
not got sv yet so can't comment on specific part but try looking at coil, ignition module or pickup
Old 26-04-08, 03:40 PM   #8
pod
Backfires are either air leaks on the inlet side or the exhaust ( air leaks on the inlet side usually cause spit back in the carbs).
A loose joint in the exhaust is worth checking for.
Check carb balance, and all mounting rubbers are correctly fitted.
With the motor running spray WD40 round the inlet stubs , if the revs rise thats where the leak is.
The PAIR valve deliberately causes backfires by allowing air into the exhausts when the engine is on overrun, ie throttle closed and engine braking from highish revs, it shouldnt do it a lot though.
Pod
Old 26-04-08, 03:46 PM   #9
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
my sv seems to pop more in warmer weather, it's got a fair bit warmer recently so might be it
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-04-08, 03:49 PM   #10
Stig
Disagree. More often than not it has to do with fueling, air mixture or carb balancing. That's not to say it isn't electrical, just that backfiring is not normally associated with an ignition fault rather fueling mixture.
Back firing and fuel cut off above 6000RPM pomo737 SV Talk, Tuning & Tweaking 0 12-03-09 07:16 PM
Firing order scorpion SV Talk, Tuning & Tweaking 27 24-08-07 12:41 PM
My first post - miss firing booner SV Talk, Tuning & Tweaking 8 16-08-06 09:57 AM
Back firing thegripper SV Talk, Tuning & Tweaking 16 04-12-05 07:24 PM
Mis-firing in the rain.. Robbo44 SV Talk, Tuning & Tweaking 20 17-10-04 09:09 PM
