Can someone please let me know if it is normal for the frame to get quite hot to touch after riding, especially around the cylinder area.
The reason I ask is I have just fitted an new exhaust and after a short ride I found the frame hot to touch, in fact too hot to keep your hand on for a long period. I'm just a little concerned that the new exhaust is leaking hot gasses and that is what is heating the frame. It is a warm day and I was mostly travelling in built up areas so only doing 40 max. Anyone help? |
The Sick Man
yep, gets very hot
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
aye my sv frame gets hot aswell you will find most bikes do the same.
thanks for quick replies.
Is there any way I would be able to tell if any of the joints are leaking? |
#5 | |
u may see some smoke comeing out of some of the joints then that would mean ther leaking slightly when i was fitting my exhaust i put a we bit of exhaust sealer round the joints on2 the heads and stuff. |
Just put your hand near to the exhaust (DON'T TOUCH IT!) and rev it, you'll feel the hot gas escape if it's leaking.
Yeap, its normal. The rear cylinder doesn't get much airflow around it so the heat builds up and transfers to the frame. Nothing to worry about mate.
Engine gets hot
Engine is connected to Aluminium (metal) frame Aluminium conducts heat well Frame acts as heatsink Heat travels into Aluminium
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#9 |
get a piece of tissue paper and put it against the exhaust and it should move where the gases are escaping
#10 |
Thanks for responses everyone, like the tissue paper idea.
SV Temperature | MattyC | SV Talk, Tuning & Tweaking | 5 | 20-10-08 07:31 AM |
What temperature should it run? | KillaSV | SV Talk, Tuning & Tweaking | 14 | 21-03-08 01:55 AM |
max operating temperature | richbeales | SV Talk, Tuning & Tweaking | 9 | 23-04-07 03:28 PM |
Temperature Gauge | T0mm0 | SV Talk, Tuning & Tweaking | 10 | 27-01-07 06:11 PM |
Running temperature! | krhall | Bikes - Talk & Issues | 8 | 12-12-06 10:49 PM |
