Old 28-04-08, 10:27 PM   #1
Tigerrrr.......
Default Gloopy petrol - what would you do?
My wife has a Honda CBR125R. Bought brand new on 1.3.05. Owing to children, it's kept in the garage and done just over 360 miles. Yes 360 miles.
It's had its first MOT & proper service where the carbs were cleaned out owing to gloopy petrol. I'm trying to keep it ticking over now to keep the oil flowing, etc, etc.
Now, the question is this. The tank is still approx 2/3rds full of petrol. Do I:
(a) drain the tank and refill with fresh petrol?
(b) top the tank up with fresh petrol?
(c) keep running the bike on the petrol already in it until it's used up?
I had the bike out yesterday and it ran fine, so I'm tempted to go for option (c).
Cheers.
Be safe, be seen.
Tigerrrr....... is offline   Reply With Quote
Old 28-04-08, 10:33 PM   #2
monkey
Default Re: Gloopy petrol - what would you do?...
I think it depends on if you're going to leave it unused. IIRC 'they' say to fill the tank to the brim before storing, or that might be the wrong way round. . If you're going to start using it I'd take it for a good straight run and if it goes ok fill it up with the good stuff. If petrol's properly gone off it loses it's smell. You may have condensation in the tank also which wouldn't be a very good thing.
I'm sure someone will be along soon to correct me.
Old 29-04-08, 05:53 AM   #3
lookskyward1
Either use the bike until the fuel is almost empty before topping off with fresh fuel or drain and re-fill.
Do not store the bike again with this petrol, it will only foul the carbs again.
Old 29-04-08, 04:55 PM   #4
TEC
TEC's Avatar
Correct
What he said
Either store the bike fully or use it, just running it for short periods and then not doing anything with it for months will cause the carbs to gum up, battery to go bad quicker, condensation* in fuel tank - tank rusts inside out, * this could also happen to silencers
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Old 29-04-08, 10:14 PM   #5
monkey
Aha. I remember being told to put an oily rag (no not a cigarette) into an exhaust before storage. Now I know why!
Old 30-04-08, 11:37 AM   #6
Blue_SV650S
SO how old is the fuel in there???
if it is <1yr then just ride the bike until it is pretty much dry. Then drain the fuel out of the carb bowl (there is a drain screw/bolt at the bottom - might be a bit of a sod to get to mind ... ).
Then lift the petrol cap, spray plenty of WD40 in there and all over any metal external part (perhaps with exception of brake discs ) take the battery out so you can keep that charged up and then just lave it ..
When you want to use it next, just throw in some nice fresh fuel, a fully charged battery and away you go!!
Old 30-04-08, 11:02 PM   #7
Tigerrrr.......
The fuel is < a year old.
The bike is kept in a perfectly dry garage with the battery linked up to an Optimate.
Cheers.
Be safe, be seen.
Old 01-05-08, 10:54 AM   #8
Blue_SV650S
Cheers.
Yep in that case, just run it out. Don't over-rev the bike to much mind as the octane will be a bit low now.
Then as I said, run the carbs dry. Does it have a fuel tap? If so an alternative is just to turn the fuel off and keep the bike running until it knonks out!
petrol tap hovis Bikes - Talk & Issues 6 13-09-07 07:58 AM
Old Petrol/Oil Grinch SV Talk, Tuning & Tweaking 19 25-04-07 06:10 PM
Petrol - Which One? krhall Bikes - Talk & Issues 36 25-04-07 08:57 AM
Out of Petrol?! Jabba Idle Banter 15 15-07-06 08:29 AM
What Petrol? Rodger Wabbit Bikes - Talk & Issues 40 15-10-04 05:50 PM
