Have the front and back calipers off at the mo, easy enough, until i tried to remove the pots from the front two.... they wont budge
![]() And to add insult to injury, trying to open the rear caliper bolts, they wont budge either, i assume they turn anti-clockwise. Anybody got some or any friendly advise as to how i'm going to remove these pots ? |
Knob faced knobster
See I told you they would be a pain to do didn't I? lol
If you look in tuning and tweaking at the post that i started called rear caliper Sid Squid gives a couple of tips in there for the seized bolts in the rear caliper. What are you using to try and get the pistons out of the front calipers?
2001 SV650 in shimmerin green, Not broken anymore |
Needle nose plyers
![]() I'll check out the thread you started alright, dont want to break any of the bolts ![]() |
I had absolute mares with my rear caliper- destroyed a pair of piston plyers in the process.
I'd suggest popping the caliper back on without the pads, bleeding it through again and pumpling the pots out- chances are the seals are all out of their grooves and may need replacing. Make sure you have a spare pair. That may also go for pad pins too. If only 1 piston comes out, clean it up, then strap (or g-clamp) it into the caliper, bleed the brake through again and pump the other one out. Painstaking, I know, but a good incentive to overhaul the brakes at least twice a year! Mine are due a post winter (has winter gone yet?!) spruce up. And don't forget the red rubber grease- if you haven't got it, order some now!!! |
#5 | |
Knob faced knobster
![]() Mine didn't fair so well on your front calipers either did they? although i managed to strip a rear caliper with them this afternoon
luckily i have a fell set of seals on hand, from the front and back
![]() broken allen key socket, where did you get those nice bolts from ![]() |
Knob faced knobster
Standard caliper bolts and a halfords pro allen socket
I see, they looked rather shiny, though you replaced them with aluminum bolts... ohh well, back to waiting until the am ..
#9 |
Knob faced knobster
the only shiny bits on my rear caliper are the stainless steel bolts that hold the caliper to its hanger and the stainless pad retaining pins
#10 |
IMO the only way to get the front pistons out is, as already suggested, connecting it back up, or by using compressed air, very lightly and keeping fingers out of the way, to force out the little blighters
Pushing pots back in | PyroB24 | SV Talk, Tuning & Tweaking | 18 | 03-12-07 01:59 PM |
Radial Calipers £100 | Stu | For Sale - SV's and SV related items | 5 | 06-11-06 11:03 AM |
front calipers | oldsvrider | Stuff Wanted | 2 | 24-08-06 08:53 PM |
Brake fluid pots | the oaf | SV Talk, Tuning & Tweaking | 2 | 06-06-06 02:16 PM |
Calipers | Hogzi | SV Talk, Tuning & Tweaking | 3 | 26-02-06 07:15 PM |
