07-05-08, 08:14 PM | #1 |
Trouble swinging radiator forward!
I'm giving my bike an oil/oil filter, air filter and plug change and can't swing the radiator forward to get to the front plug.
I've removed the lower bolt and loosened the upper two. It moves slightly, but nowhere near enough to get to the plug. Any help would be great! |
07-05-08, 08:23 PM | #2 |
Re: Trouble swinging radiator forward!
when i was messing with the front plug, the radiator did seem to have a very finite distance of motion
...but was still enough just to get the plug spanner in with a fiddle if thats the case? (although i am useless so... wait till someone knowledgeable comes on) |
07-05-08, 08:24 PM | #3 |
Are you using the plug spanner that came with the bike? The rad doesn't need to move a great deal to get it in as it is hinged.
'52 Curvy S | So good.....it made me want to trump! If at first you don't succeed - use more gaffa tape. |
07-05-08, 08:25 PM | #4 |
Remove the horn, it's a 10mm hex head bolt
07-05-08, 08:37 PM | #5 |
Curvey?? You also have to unplug the rad pegs into the rubber grommets in each fairing side.
It's not necessary to remove the fairing, just undo the fixings and flex it outwards a bit. A bit of soapy water as lube can help if the grommets are stuck onto the pegs.
07-05-08, 08:47 PM | #6 |
Rad plugs? I've loosened the upper mounting bolts as described in the manual, which is specific to my bike (yep, curvy, 2000).
07-05-08, 08:53 PM | #7 |
Pull the fairing gently, either side at the bottom. Theres a mount either side that sits in a rubber mount.
07-05-08, 09:00 PM | #8 |
This is the locating mount on the rad. One each side.
07-05-08, 09:40 PM | #9 |
07-05-08, 09:46 PM | #10 | |
swinging arm suspension linkage bearings | 21QUEST | SV Talk, Tuning & Tweaking | 13 | 05-08-08 01:40 PM |
Engine/swinging arm Castle Nuts Socket | 21QUEST | SV Talk, Tuning & Tweaking | 0 | 15-02-08 11:34 AM |
scratched the black paint on my swinging arm | ged | SV Talk, Tuning & Tweaking | 2 | 14-01-07 09:04 PM |
K4 swinging arm on 2000 SV Naked Curvy | Sloth | SV Talk, Tuning & Tweaking | 3 | 29-11-05 02:21 AM |
Swinging arm pivot greasing | curium | SV Talk, Tuning & Tweaking | 3 | 03-04-05 04:40 PM |
