Old 08-05-08, 08:51 AM   #1
poisonidea
Default Cyclinder Issues, help greatly appreciated!
Ok so, for the last few days my K6 has been running a bit wierd, at high revs you could hear one of the cylinders occasionally misfire and at low revs (idle) it runs only on 1 cylinder at <1000rpm then stalls.
So after reading alot of posts on here, thought it must be water in the plugs, so removed both, they were both black and stank of petrol so gave them a dry/clean and put em back....no difference.
Went to bed.
The morning came, and me being an optimist thought the bike fairies might have been out during the night it might now work.
No change.
Still thought the problem was with the plugs so went to halfords, bought some shiny new ones, fitted them.
No change.
About half hour later went to start the bike again and now it wont even start. Getting pretty annoyed by this point, I pushed it down to my nearest garage which was a Yamama place about 2 miles away in the baking sun. As my Suzuki dealership is closed on wednesdays and I needed the bike fixed for today.
Garage told me my battery is screwed and I need a new one. As I was in a hurry to sort it out I agreed, £45 for the battery i was told. I was told the battery would be charged and fitted by 4pm. By this point I'd decided there was no point in going to work on public transport so called in to say I was having somekind of breakdown .
4pm: Walk back down to the garage, told it cost £78 (£49 battery, £2 labour...nice.
No change.
Took the bike out for a thrashing to hopefully clear out some of the crap near the plugs....You guessed it, still no change. Had another look at the NEW plugs, front is black and sooty, back is black and petrolly (the garage told me it was the back that wasn't firing properly)
Luckily my dad's lent me his bandit till I get it sorted
Sorry for the long post but my questions are:
1) Does anyone have any idea what could be happening here and if so how can it be fixed?
2) When I take the bike to the dealership at the weekend would the work be covered by warrenty? (bike under 2 years old)
Any Help gratfully received
Chris
Old 08-05-08, 12:45 PM   #2
Default Re: Cyclinder Issues, help greatly appreciated!
I don't know what your issue is I'm afraid, but £20 labour to fit a battery 6 screws and 5 minutes.
Old 08-05-08, 01:30 PM   #3
I hope they used lube with that...
Sounds like it's running sloppy rich to me, is there a fault code displayed?
If the throttles are seriously out of balance this won't help.
The fact that it's only one cylinder, to me rules out the water temperature sensor, auto enrichment and MAP sensor.
Dead mice in the airbox? (seen this one before...)
Old 08-05-08, 02:49 PM   #4
jambo
jambo's Avatar
The first thing to check is whether this is spark or fuel. If the engine's running badly enough I can imagine the Fuel Injection bumping up the mixture to try and correct, so it's possible a dodgy spark is causing the black plugs. On a carbed bike I'd be looking to check for stuck choke plungers and restrictions in the air box.
At least one person has had problems on the K6 with one of the coils breaking down. This put them down to one plug firing all the time, and one cutting in and out. Check both plugs are sparking when the engine's running. I'd see if you can borrow a rear coil off someone (assuming it's the rear thats the problem). If you sub that in and it runs fine, then you know what you need to buy / claim under warranty. If it makes no difference you've eliminated one thing
Jambo
Electrical fault, help much appreciated! samwilko SV Talk, Tuning & Tweaking 3 24-08-08 12:31 PM
RF900 - Any info appreciated Larry Bikes - Talk & Issues 24 09-06-08 02:14 PM
Moved: Cyclinder Issues, help greatly appreciated! poisonidea Bikes - Talk & Issues 3 08-05-08 12:04 PM
Help and tips appreciated silver surfer SV Talk, Tuning & Tweaking 16 12-06-07 12:32 PM
Help appreciated Moriarty Soho Massive 1 11-04-06 12:36 PM
