Old 12-05-08, 10:05 AM   #1
butterick99
Default Engine Breaking? Hopefully not. Engine braking - is that OK?
Maybe a silly Question but im a relatively new young rider... getting to know my bikes.... but i have a silly question which i havent really thought about.... Does Engine breaking damage your bike or have any effect on it at all......
Just curious because i do engine break every now and again!!
D
Old 12-05-08, 10:09 AM   #2
Alpinestarhero
Default Re: Engine Breaking
No; using engine braking is fine - so long as when you shift down the gears, you dont over rev the bike!
Old 12-05-08, 10:09 AM   #3
Biker Biggles
Biker Biggles's Avatar
Old 12-05-08, 10:16 AM   #4
Ruffy
Ruffy's Avatar
Engine breaking is seriously bad news.
Engine braking, however, is usually perfectly fine if you're gentle with the clutch and don't let it over-rev.
(Sorry, I couldn't resist being the english teacher. I tried but just coudn't leave the keyboard alone!)
Incidentally, despite my sarcasm above, OP I don't believe there's such a thing as a silly question. Asking questions is the only way to learn.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 12-05-08, 10:23 AM   #5
So, you downshift through the gears to slow you down. There's 2 possible sources of damage.
Not blipping the throttle and just banging down through the gears, this is never going to be good as it makes crunchy noises. Crunchy noises in gearboxes are generally expensive.
Downshifting at 10krpm, this is going to rev the balls off the engine with the possibility of breaking things due to the extra load on everything, for example the camchain will have far more inertial forces on it than normal, you risk valve float, and piston speed is higher, giving more stress on conrods.
All these things are possibly very catastrophic and instant failure.
So, IMO, do it smoothly, and don't try to get it to rev higher than the limiter and it's fine.
Old 12-05-08, 10:38 AM   #6
SoulKiss
SoulKiss's Avatar
A wise man (who on account of it being his Birthday today, must be even wiser now than when he told me this in answer to the same question)
Using engine braking along with regular braking is fine and good.
Using engine braking alone is not so good as clutches are more expensive than brake pads.
Old 12-05-08, 11:21 AM   #7
butterick99
A Valuable Point.......... Thank You!!
Old 12-05-08, 11:32 AM   #8
petevtwin650
Depends if you're going to put enough miles on a bike to need changing the clutch. Anyway what's a set of clutch plates cost? 80 quid? Two sets of front pads replaced twice, 80 quid and maybe four rears, 32 quid?
Not really a relevant arguement I reckon.
Using engine braking can be smoother and more controlled IMO.
Old 12-05-08, 11:33 AM   #9
Also, how does engine braking wear clutches out if you match the speeds then fully release it? I don't think the wear penalty will be that big.
Old 12-05-08, 03:17 PM   #10
Warthog
Default Re: Engine Breaking? Hopefully not. Engine braking - is that OK?
Just do both engine braking and normal braking smoothly together, thats the best!
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
Engine braking Lakes_Puma SV Talk, Tuning & Tweaking 18 02-06-07 02:30 PM
engine braking on the sv! kwak zzr SV Talk, Tuning & Tweaking 11 25-04-06 12:01 PM
Braking an engine svrash For Sale - SV's and SV related items 1 22-03-06 10:43 AM
Engine braking curium Bikes - Talk & Issues 21 29-03-05 04:52 AM
