Old 02-06-08, 06:58 PM   #1
Probrox
Default Newbie
I'm a newbie to the forum but i've had the SV for two years now. Anyway, thought i'd get some pictures up as i've just had a re-spray in matt black.
Before
After
AS you can see from the headlight bracket and the clocks this used to have a fairing. Anyone know if I can chop the bracket off and replace with the one from the unfaired model? Does the unfaired model bracket bolt on or is it welded?
Old 02-06-08, 07:02 PM   #2
b_1_rd
Default Re: Newbie
looks a nice job
Old 02-06-08, 07:04 PM   #3
Gene genie
Default Re: Newbie
can we see one from the front?
Old 02-06-08, 07:05 PM   #4
Girth
Default Re: Newbie
Welcome!
Bikes looks better in black and get that can cut down!
Old 02-06-08, 07:10 PM   #5
Probrox
Default Re: Newbie
Originally Posted by Girth View Post
Welcome!
Sounds like a plan, easy to do??
Old 02-06-08, 07:50 PM   #6
tanis34
Default Re: Newbie
welcome looks like job well done
Old 02-06-08, 10:56 PM   #7
haggis
Default Re: Newbie
Hi there and welcome. Nice simplistic paintjob, well done.
Originally Posted by Probrox View Post
.....AS you can see from the headlight bracket and the clocks this used to have a fairing. Anyone know if I can chop the bracket off and replace with the one from the unfaired model? Does the unfaired model bracket bolt on or is it welded?
Like quite a few others on here, I've converted mine from faired to naked.
Not too sure what you mean above, but i think you're asking about replacing the subframe bracket with the standard naked item? The faired one is bolted at the headstock lugs (two bolts) but i believe the naked clocks were bolted to the underside of the topyoke.
So for a proper faired to naked conversion you'd need...
Naked topyoke (rare-ish)
Naked clocks + bracket (golden hens teeth)
Some kind of headlight set up too. (ten a penny!)
Old 03-06-08, 08:59 AM   #8
Luckypants
Luckypants's Avatar
Default Re: Newbie
A very nice looking mo'cicle there mate. Loving the matt black finish.
Old 03-06-08, 09:12 AM   #9
Jester666
Default Re: Newbie
That can is in desperate need of 'stubbyfication'. Nice looking bike!
Old 03-06-08, 09:20 AM   #10
Alpinestarhero
Default Re: Newbie
i think i have seen a fully faired green rizla SV on the pictures in the main site accomyaning this forum......
Anywho, i prefer the black finish. Looks great, lozzo will be proud!
Welcome to the forum
Newbie to all newbie’s and experienced riders / question. tonyk Bikes - Talk & Issues 17 03-06-08 08:12 PM
Another newbie obanmac Idle Banter 10 24-04-08 04:02 PM
Newbie.... popeye Idle Banter 19 24-04-08 10:51 AM
Newbie saying hi toadie Idle Banter 26 15-04-08 08:17 AM
Newbie Wanny Guildford Massive 25 01-12-06 07:46 AM
