Old 04-06-08, 03:52 PM   #1
pencil shavings
Default ibuprofen and alcohol
My sholder is still giving me jip, and Im going out tonight (student style) is it ok to take it? I tend to get stomach aches when I have ibuprofen on an empty stomach, so I think its prob not worth taking it.I might just deep heat my sholder instead.
The alcohol will nub the pain anyway.
Any advice?
Cheers!
Old 04-06-08, 03:53 PM   #2
Bluepete
Bluepete's Avatar
Default Re: ibuprofen and alcohol
My advice?
Drink lots.
Old 04-06-08, 04:06 PM   #3
timwilky
timwilky's Avatar
Strange my shoulder is hurting big at the moment, only 5 years since I did no damage to it with a so called soft tissue injury. Been hitting the Tramadol. Alcohol has been limited to afternoon Pimms and evening Port.
Side effect. :- can't poo
Not Grumpy, opinionated.
Old 04-06-08, 04:09 PM   #4
Davies
Ripped from here:
Aspirin and ibuprofen
Aspirin and ibuprofen are both available without a prescription from pharmacies. It is normally safe to drink alcohol when taking ibuprofen or aspirin, as long as you drink within the recommended amount (between 3-4 units daily for men, and between 2-3 units daily for women).
If you drink more than this while taking aspirin or ibuprofen, the alcohol can irritate your stomach, and may increase your likelihood of experiencing side effects, such as bleeding in your stomach or intestines. Heavy, or long-term, daily use of aspirin may cause stomachinflammation, or ulceration, and this can be made worse by drinking too much alcohol. Aspirin can also increase the effects of alcohol.
If you often drink more than three units of alcohol in a day, you should talk to your GP about whether or not it is safe for you to take aspirin, or ibuprofen.
Saying all of that though, I've done it in the past and had no side effects. My solution......drink loads, and pop a few with a couple of pints of water before you go to sleep......should help with the hangover too
Old 04-06-08, 04:17 PM   #5
pencil shavings
ok, drink lots seems to be the message that im getting! And I will not let the faithfull down!!
Ive put some ibuprofen gel on my sholder, that seems like the compromise!
drunken pictures to follow.................
anyone want to set me any chalanged for the night?? lol
Old 04-06-08, 04:18 PM   #6
CoolGirl
that works for me too.
this is fast turning into Ill Banter!
Old 04-06-08, 06:32 PM   #7
chutz
when taking any non steroidal anti inflamatory drug you should always have eaten before taking as they inhibit the production of enzymes in your gut and cause damage to it unless it has food inside. As for drinking, never stopped me. Just have the keebab before for a change!!!
Old 04-06-08, 06:32 PM   #8
MavUK
Drinking - I don't know for sure, the doctors over here say 'You're english so you can drink but we wouldn't say that to a local' when I ask about drinking with pills
However... Don't take it without eating. The tablets can cause ulcers etc if taken on an empty stomach, and it's not surprising that you get aches when taking it like that...
Old 04-06-08, 06:34 PM   #9
pencil shavings
hmm, i should read the instructions before I take drugs next time! lol
Thanks for the advice!
Old 04-06-08, 06:46 PM   #10
MavUK
Alcohol Typing Limit Lifeboat Mike Idle Banter 42 29-12-08 10:01 PM
Alcohol and Pretzels DarrenSV650S Idle Banter 3 01-11-08 02:21 AM
Alcohol appollo1 Idle Banter 17 04-08-08 05:52 AM
What is Rubbing Alcohol ? Richie Idle Banter 17 29-03-07 08:51 PM
alcohol carelesschucca Idle Banter 21 14-04-06 06:51 PM
