Old 05-06-08, 08:46 AM   #1
SoulKiss
SoulKiss's Avatar
Default Ever worry about having too little oil in your engine? No, I check it every now and again.
Now not saying that this is a good thing.
Not saying that it wouldnt reduce the overal-lifespan of the engine, but this is interesting....
Old 05-06-08, 08:49 AM   #2
Skip
Skip's Avatar
Default Re: Ever worry about having too little oil in your engine?
lol - I was about to post that!
Kawasaki FTW!
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 05-06-08, 08:51 AM   #3
ogden
ogden's Avatar
How old is that article? I recall PB or Bike or someone doing a test like that several years ago.
ogden
S1000XR | 990SMT | YZF-R6 #7
ogden is offline   Reply With Quote
Old 05-06-08, 08:56 AM   #4
Stig
I do believe that IS the article. And it has to be a minimum of 10 years old.
Old 05-06-08, 08:58 AM   #5
Skip
Skip's Avatar
10 years old or not - its still impressive...
'81 Honda H100A
Old 05-06-08, 10:01 AM   #6
jambo
jambo's Avatar
I'd guess more like 5. The bike's a '97 ZX6R F model registered in '98, which had done 20,000 miles and depriciated to the point that it was considered sacrificial for this article.
Very impressive, but as stated in the article, not representative of the engine being used under road conditions, not least because the fact the engine was bolt upright kept the oil feed from running dry in the 2nd test.
I would be intrested in stripping the engine down and seeing what the head and bores looked like given the temperatures involved. Still, kudos on the fact it carried on, I'd have put ?5 down against it surviving. I have a feeling had they stopped short of bouncing the bike off the rev-limiter, and carried on using 8,000rpm, thus not having a problem with unburned fuel igniting in the exhaust causing an abort, that it would not have survived the 2nd test.
Jambo
Old 05-06-08, 10:14 AM   #7
Bear
Hmm, who do we know who has a '98 zx6r, with significantly higher mileage than this and the mechanical know-how to probably fix any problems recreating this experiment would cause...
Old 05-06-08, 10:22 AM   #8
SoulKiss
SoulKiss's Avatar
Haven't you just transposed the test to a ZX-9 tho, with the same gentleman with the same mechanical know-how on hand to fix any problems this recreation causes?
Old 21-07-08, 08:03 AM   #9
Paul the 6th
Paul the 6th's Avatar
Default Re: Ever worry about having too little oil in your engine? No, I check it every now and again.
So, has anyone tried this at home yet? I don't think I'll try it.
(joke)
Old 21-07-08, 09:50 AM   #10
Alpinestarhero
I too would have liked to see some info on how the inside of the engine looked after that treatment; even if they just took out the spark-plugs and showed them compared to a normal-used 20,000 mile kwak engine and then against new spark plugs.
Reassuring article though. I think I'll make a little trip to the rev-limiter next time I'm in second gear and in a tunnel
Matt
Ticking sound in front of the engine - Should I worry? andreis Bikes - Talk & Issues 18 30-04-09 08:26 AM
Newbie: Engine noise - Do I need to worry? VolatileParsley SV Talk, Tuning & Tweaking 3 22-05-08 10:01 PM
New bike for me. don't worry it's still a twin hall13uk Bikes - Talk & Issues 100 25-04-07 12:42 PM
Want to Know About Engine Oil? - Check This Out I'm_a_Newbie Bikes - Talk & Issues 26 19-03-06 09:24 PM
Oil or Check engine light is on wilsonma08 SV Talk, Tuning & Tweaking 0 16-08-05 06:00 AM
