Old 09-06-08, 02:34 PM   #1
Blue_SV650S
Default Extending the stock shock
Ok, ground clearance on a stock SV is poor. There is the shorter dogbone trick, but this is limited.
My track SV has an ohlins rear shock, I can tell you for nothing the biggest difference it makes is in where you can adjust the ride-height!! You really can wind the shock up!! But race shocks are stupidly expensive ... and I am not sure the largest gain is actually in the more controlled damping, just in the ride height ...
So this leads me on ... has anyone actually tried extending a stock SV shock? To my mind making longer fork bottoms seem to be the simplest way?
Old 29-10-08, 08:02 AM   #2
philbond07
Default Re: Extending the stock shock
Hey Blue,
I want to change ride-hight by lifting up my k3 a bit on the rear; don't wanna use shorter dogbones. So because my oem shock is still ok I have been thinking of extending the stock shock too, by exactly same way as you describe. have you gone any further in this? I think best would be to produce a U-piece which goes internally into the U at the stock-shock, and then comes out with same width, extending it by say 20mm, so you can drill holes inthere to fit bottom again.
Old 29-10-08, 09:48 AM   #3
Blue_SV650S
Nope, never did anything ...
Would you weld or bolt this new for metal bit on?
Old 29-10-08, 10:54 AM   #4
Dangerous Dave
OEM shock isn't rebuildable, so doing internal work may be a bit of a problem.
Shorter linkages are far cheaper and easier to do.
Old 29-10-08, 11:21 AM   #5
How much of a difference in length is needed?
Blue seems to come across as a guy who feels he needs an extra bit of length
Old 29-10-08, 11:48 AM   #6
philbond07
Hmmm both I guess: stick bottom planes of the 2 "U"'s to each other, bolt thru the original hole, & fortify with some weld points. I guess this must be a safe construction for 3-4 years to come?
Old 29-10-08, 11:53 AM   #7
philbond07
True, but then the swingarm angle gets steeper and the chain uses up the swingarm-protector quicker etc....
Old 29-10-08, 11:56 AM   #8
Er? You'll have quite a job on increasing ride height without deflecting the swingarm fella
Old 29-10-08, 11:57 AM   #9
philbond07
That's a good question.
Since I mounted hyperpro springs to the front I have the impression the bike's front is too high. As I also want to keep some rideheight I prefer to get the rear up too. How much? Not the slightest idea
I'd say what most standard aftermarket shorter dogbones do with a K3+: +25-30mm. Though I'm not sure what this distance means: is it the shock which is "pushed up" by that amount, or is it the very tail (ledlights) of the bike which comes up by that distance?
Old 29-10-08, 12:01 PM   #10
philbond07
Is it? I thought simply extending length of the shock doesn't influence swingarm angle a lot, clearly not as much as changing lenght of the dogbones.
Thinking of reverting back to stock shock ... Blue_SV650S SV Talk, Tuning & Tweaking 31 19-09-08 12:33 PM
Extending the stock shock Blue_SV650S SV Talk, Tuning & Tweaking 1 09-06-08 02:52 PM
Extending the fuse box. Grinch SV Talk, Tuning & Tweaking 5 26-06-07 09:47 PM
GSXR rear shock stock spring rates lukemillar Bikes - Talk & Issues 3 07-05-06 01:38 PM
stock sv1000 shock settings mac650s SV Talk, Tuning & Tweaking 1 26-11-05 09:12 PM
