Ok, i need help (mentally and bike wise)
a few months back i posted about a clunk and shudders. so i adjusted the clutch at the level and it was fine. at an IAM meeting, it was mentioned that i had no freeplay in my clutch. so the observer adjusted it to have enough free play, but then it did the clunking and shudders, which i figured out is that the clutch is trying to drive the bike when level is fully in. now it seems, if i have freeplay the clutch doesnt disengage when the lever is fully in, but if i have no freeplay then it seems to run fine. Hope someone can help, Adam |
Have you tried adjusting the clutch at the other end?
I'm having a similar thing with mine, I prefer to have the clutch set so it disengages with the minimum travel possible, so I just do a 2 finger job, but due to the aftermarket (GPZ) lever it does take a bit more than I'd like. Using the adjuster by the worm drive made a big difference though. FWIW I have very little free play in mine, as far as I understand it's to make sure that going from lock to lock won't cause your clutch to start to disengage that's all. Ste
Had an SV or three. Street triple R - gone but not forgotten. Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course. |
#3 | |
Certainly look at the worm drive as Ste suggested. ![]() |
thanks guys, will do it 2moro when working on the bike.
got new pads to put in all round. may stubby the fuel exhaust aswell! |
Freeplay in the clutch lever? | svrich | SV Talk, Tuning & Tweaking | 5 | 02-03-09 11:34 AM |
Clutch Problem? Cutting off when releasing clutch in first gear! | puthsardarade | SV Talk, Tuning & Tweaking | 15 | 09-01-08 09:42 PM |
MOT Due - Swingarm Freeplay | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 4 | 18-04-07 07:46 AM |
Front brake 'freeplay'. | Fuzz | SV Talk, Tuning & Tweaking | 17 | 16-07-06 08:49 PM |
Clear clutch covers to see the clutch spin while running. | TLRMAN | SV Talk, Tuning & Tweaking | 13 | 01-11-04 02:18 PM |
