Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 20-06-08, 09:15 PM   #1
DavieSV
DavieSV's Avatar
Default Abba Stand
Got a Abba stand for Fathers day
What a wonderful tool
Easy to use & makes working on the bike so easy
using a jack under the engine, both wheels can be lifted from the ground.
Work can be carried out on wheels, brakes, suspension and more with ease.
Never need to use paddock stands again
Only down side I can see, is that when lifting the bike up, the stand pushes the side stand up, so DON'T forget to put it back down when you lower the bike back to the ground
DavieSV is offline   Reply With Quote
Old 21-06-08, 11:48 AM   #2
Grinch
Default Re: Abba Stand
I've got one too, you can even get a kit that bolts into the foot peg mounts and then you can remove the swing arm.
Old 21-06-08, 12:02 PM   #3
Yes get the swingarm removal tool, then you can use it on any bike too.
Old 21-06-08, 03:38 PM   #4
DoubleD
I love my abba stand as well.
Old 22-06-08, 08:40 AM   #5
El Saxo
I love mine too, though I'm not sure about jacking up the front for removing the front wheel etc - the bike seemed to be really unsteady when I tried it.
I'm planning on getting one of those stands that lifts the front at the headstock (at least I think that's what it's called ).
Old 22-06-08, 08:41 AM   #6
But then you can't get the head bearings off
Tie the bike to the roof if it feels unsteady, the usual cause when you support the bottom of the engine is it wants to balance on the engine instead of the stand.
Old 22-06-08, 08:50 AM   #7
DavieSV
DavieSV's Avatar
put the jack as far forward as possible
a couple of inches makes a difference
I placed my jack just behind the oil filter, steady as a rock
Old 22-06-08, 08:52 AM   #8
Me too
Old 22-06-08, 09:07 AM   #9
El Saxo
ah ok, I'll try it again then and try the jack in a different spot, maybe I had it too close to point where the stand holds the bike (the swingarm pivot?).
Old 22-06-08, 09:11 AM   #10
Sounds like it.
Paddock stand/abba stand or? Ruthja2801 Bikes - Talk & Issues 18 26-02-09 12:20 PM
Abba Stand G Stuff Wanted 0 25-09-08 03:57 PM
center stand / abba stand? New Leaf Bikes - Talk & Issues 3 29-01-08 01:58 PM
Abba stand grahamy SV Talk, Tuning & Tweaking 1 07-07-07 08:21 PM
Help abba stand the_runt69 Soho Massive 7 30-04-07 11:38 PM
