Old 30-06-08, 09:29 PM   #1
Grinch
Default Rebuilding the SV fighter.
Well its been a busy day for me trying to catch up on the work I should have done last week, but here is today's progress.
First I had to remove the swing arm and put the chain and chain rubber, as I had removed it as one loop rather then split it.
Here you can see the threaded link into the ZX636 shock (B1H) that I fitted.
And it from the other side.
After which I put on the back wheel, and fitted the exhaust header pipes and the Remus end can.
Same again.
Then I fitted the choke cables, which needed me to remove and refit the carbs, and I fired the bike up. Wasn't running on the front until I noticed I knocked a live off the coils, which was why the rev counter stopped moving.
So I fitted the nose cone and parking light, testing the bulbs and cleaning the connections as they didn't work at first.
But before that I had to mod the break fluid reservoir mount
Here's the fitted and moded mount.
Moved brake line splitter.
And the Brake reservoir mount with its favourite mod.
After that I tidied up all the wiring and sorted out a mounting for the fuse box as its been moved to the rear seat.
As you can also see I put the rear plastics on and light for a test viewing as I need to get things lined up too fit the undertray tomorrow.
And here is a little vid of the bike running after not being started since last year.
Old 30-06-08, 11:03 PM   #2
Grinch
Default Re: Rebuilding the SV fighter.
The only problem is that I only have enough cash spare to MOT one bike as Helga runs out this week, so which one...
Old 01-07-08, 02:58 PM   #3
Grinch
Ok a few more photo's after I cut out and put on the undertray.
Old 01-07-08, 05:58 PM   #4
Grinch
Well the undertray is all sorted, and will just need painting, so now I've been working on the number plate and indicator hanger. At the moment its just a box as I wanted a strong mount, and some where to hide wires. So the shape is there, next is the cleaning up and hole cutting.
While I was out there and had put the back together to get the undertray right I popped the rest of the plastics on to get a look at it.
Now that I know I don't have the spare cash to get it MOT'd, Tax'd and Insured for the AR its making me a little depressed now.
Old 01-07-08, 06:11 PM   #5
plowsie
MOT this one mate if you can More multi coloured than Stewies was
Old 01-07-08, 06:46 PM   #6
What colour will it be
Old 01-07-08, 07:35 PM   #7
Grinch
I'm thinking British Racing Green, but will have a play with photo shop later.
Old 02-07-08, 06:33 PM   #8
Grinch
Well its been a crap day to day, as most of the work stopped because of the weather. And when I did get to the caliper the bolts holding it together a stuck solid, so I'm trying to free up another caliper I have that has a stuck pistons.
Old 02-07-08, 09:21 PM   #9
mattc
Did you helicoil the bottom bolt of the shock?
Old 02-07-08, 09:23 PM   #10
Grinch
I didn't a army mechanic mate of mine did as he has the kit to do it.
Rebuilding Front End - 2002 Curvy slloyd SV Talk, Tuning & Tweaking 24 14-05-09 03:18 PM
Rebuilding calipers? irl_dar SV Talk, Tuning & Tweaking 54 06-03-09 10:33 PM
Rejetting and Rebuilding carbs . help drag SV Talk, Tuning & Tweaking 19 26-01-09 11:27 AM
Rebuilding '03, Need: forks, radiator, headlamp Broncstang Stuff Wanted 0 13-11-07 03:23 AM
rebuilding SVS, do I have a choice of motor? dizzzzz SV Talk, Tuning & Tweaking 1 14-01-07 02:38 PM
