Track Days Post up here about trackdays
Old 02-07-08, 10:57 AM   #1
gettin2dizzy
Default Trackday Tyre Pressures
What do people run them at for trackdays?
Cheers,
Rob.
Old 02-07-08, 11:00 AM   #2
G
Default Re: Trackday Tyre Pressures
5 - 6 psi under what you would on the road.
There will probably be a tyre man there aswell to give you advice on the day so its more specific to track temps and weather on the day.
6.67300 × 10-11 m3 kg-1 s-2
Old 02-07-08, 11:52 AM   #3
Tim in Belgium
I've taken to running my Metzler Rennsport Roads at 30 psi front and back when out on track, seem to work pretty well.
Old 02-07-08, 12:27 PM   #4
gettin2dizzy
cheers.
And the front one higher?!
Old 02-07-08, 01:04 PM   #5
Lozzo
29R 31F on the CBR600, which has the same tyres sizes as the SV650S I also own. If I was to take the SV on track I'd run the same pressures. I run Rennsport road compounds at the moment, but soon changing to a Bridgestone slick front and Rennsport RS2 race compound rear at the same pressures as before.
The CBR handles beautiully as it is, hopefully the new tyres and Maxton shock will make it even better.
Old 02-07-08, 03:19 PM   #6
Zombie Jesus
I use 30/30 forgot to pump them back up after the last trackday and it didn't handle much different on public roads. Also forgot to put my numberplate back on for the 5 mile trip to the petrol station at lunchtime
Old 02-07-08, 03:58 PM   #7
flibble
We rode ours with 32 front and back (cbr600 and zx6r), but then we're in the numpty novice group.
Old 02-07-08, 06:03 PM   #8
weazelz
I use 30/30
Old 04-07-08, 11:13 AM   #9
charlie13
i started off with 33 front 31 rear on the curvy, then checked the hot pressures after the first couple of sessions and adjusted so they were 36 front and rear.
Old 04-07-08, 07:12 PM   #10
Tim in Belgium
It was stonking hot today at Croft, my mate had to let his rear down even further, god damn that moist Nordschleife air.
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre Pressures redbiker 954 Mini-Twins 5 21-02-08 10:25 PM
Tyre pressures mxm35948 SV Talk, Tuning & Tweaking 13 10-09-07 04:18 PM
Tyre Pressures fullstop102 SV Talk, Tuning & Tweaking 8 30-06-06 02:54 PM
Trackday tyre pressures? andyaikido SV Talk, Tuning & Tweaking 7 22-12-05 04:13 PM
