Old 03-07-08, 12:53 PM   #1
svrob
Default Rounded allen bolt
Hi all
I have a rounded 5mm allen bolt, can't get grips on it or anything, any ideas as to how it get it out?
Thanks
Old 03-07-08, 01:34 PM   #2
suzsv650
Default Re: Rounded allen bolt
Cut along the bolt so you can get a flat blade in there or get a punch and punch round the edge
Old 03-07-08, 01:39 PM   #3
Spanner Man
Afternoon all.
Try gently tapping an old spline or Torx bit of the appropriate size into the offending Allen screw. Works for me 9 times out of 10.
Cheers.
Spanner Man
Old 03-07-08, 01:47 PM   #4
Baph
Originally Posted by Spanner Man View Post
...Torx bit of the appropriate size into the offending Allen screw. Works for me 9 times out of 10.
+1. Torx or similar bit of a slightly larger size than the round hole, tap in gently.
Old 03-07-08, 01:47 PM   #5
gettin2dizzy
Or go to halfords and buy an extractor set.
Old 03-07-08, 02:38 PM   #6
svrob
How do these work?
Old 03-07-08, 04:10 PM   #7
svrich
A reverse thread that bites into the bolt head and cuts in to grip as it rotates to 'extract' the offending bolt. A clever and simple gadget
Old 03-07-08, 07:26 PM   #8
mac
Use the ball end of a ball pein hammer and tap the head of the cap head, then use a brand new 5mm allen key and try and get it out.
Screw extractors need a suitable pilot hole drilling through the bolt head first, so best to try and get it out other ways.
A good release spray is worth its weight in gold, Plusgas rocks (WD 40 is better as a water dispersal and general lubricant than a release agent)
If you need a set of extractors PM me and you can borrow a set.
Mac.........
Old 04-07-08, 07:39 PM   #9
svrob
Mac.........
Hi Mac
Thanks, will give it a go and if all else fails may call on you for the extractors.
Rob
Old 05-07-08, 01:32 AM   #10
xXBADGERXx
+1 on that . I use this method to get seriously damaged cap heads out of Battle Tank sights . Another handy thing to have at hand is a set of Imperial sized Allen keys , sometimes one of these will fit a damaged metric cap head . Ball Pein hammer method is also good for shocking the bolt and helping it release the corroded threads , I usually use a pin punch for that method , wont deform the head too much and helps knock the damaged cap head back into a salvageable situation .
Allen Bolt Chain Adjuster Thingy! Ash999 SV Talk, Tuning & Tweaking 10 05-03-09 12:21 PM
help - rounded off allen bolt. New Leaf Bikes - Talk & Issues 31 29-01-09 10:28 PM
Rounded bolt, any help please? Brettus SV Talk, Tuning & Tweaking 14 27-10-08 10:45 PM
Allen head bolt 2000 sv yanto SV Talk, Tuning & Tweaking 2 04-08-08 11:07 PM
Seized allen bolt FishyMug SV Talk, Tuning & Tweaking 6 16-10-07 10:19 PM
