Old 12-07-08, 10:49 AM   #1
krhall
Default Rounded Nut?
I have managed to round the nut at the end of the swingarm, the one used for tightening the chain, so two questions:
1. How the hell do I now get it off?
2. Where can I get a replacement?
3. Is there a particular part no?
OOps that 3 questions.
Cheers,
Kev
Old 12-07-08, 11:52 AM   #2
Default Re: Rounded Nut?
How did you knacker it? - it doesn't carry any load.
Undo the spindle and pull the wheel back a dab, then the nut won't be under any tension - you'll probably be able to undo it with your fingers, (unless the thread is goosed too).
It's an M8 nut and nothing special, (well, the original is flanged, but any nut that fits will do), so any hardware or DIY shop or similar.
Yes, Suzuki probably give it a number, (although it may be supplied part of the adjuster assembly), but it's just a nut.
You can't count.
Cheers, Kev
S'Ok.
Old 14-07-08, 07:12 AM   #3
krhall
Cheers SS!
Old 14-07-08, 04:06 PM   #4
Ceri JC
As SS says, plus in answer to question one: try using a 12 sided socket (sometimes even a slightly different sized one- eg the nearest imperial size) on the end if it is already so cheesed off as to be ruined. You'll still have to replace it, but it should be easy(ish) to get it off. I've even heard of people hammering 12 sided sockets onto an offending rounded nut to get if off, but that smacks of a real bodge (and of course there is scope for marking, or even knackering the socket, even if you protect the back end with a rag)!
Old 14-07-08, 04:10 PM   #5
tonyk
tonyk's Avatar
or even file 2 sides flat enough to fit a adjustable spanner on to it...
my 2 p worth..
"Meh" - ASM Forever, RIP. 13/03/1986 - 05/04/2008
"Better to keep your mouth shut and appear stupid than to open it and clear all doubts."
Some days its not even worth chewing through the restraints...
tonyk is offline   Reply With Quote
Old 14-07-08, 04:12 PM   #6
jambo
jambo's Avatar
In my experiance, a 6 sided socket will almost always grip better than a 12 sided one, especially if the nut is past it's best, as it applies force to the flats rather than the points of the nut. As SS points out though, once the axel nut is undone there should be no load at all on that nut.
Jambo
Old 14-07-08, 08:23 PM   #7
skidmarx
Cheers,
Kev
Quite a few mechanical woes of late!
A rounded nut in that situation should not really be a problem if your going to tackle a chain adjustment competently. If your not sure, I'd get it done at a shop tbh
Old 15-07-08, 07:29 AM   #8
krhall
The chain is on its last legs, I was giving it its final adjustment prior to replacing the chain and sprockets this week.
......and it is proper rounded, but as mentioned once the axel is wound off the wheel adjuster will be under no load and should be easy to get off. Always helps me to get a bit of reassurance from more competant peeps than me before doing something.
Rounding a nut and sinking the Beemer aren't quite in the same bracket, but I have to say it does sort of follow suit............my luck is poxed!
Old 15-07-08, 07:49 AM   #9
K
Well rounded nuts are no problem...
... don't they just get released into 'Care in the Community'?
Old 15-07-08, 07:51 AM   #10
Viney
You'd know K
How on earth do you round that nut? I would say its impossible, but it looks like it isnt! you have undone the spindle?
help - rounded off allen bolt. New Leaf Bikes - Talk & Issues 31 29-01-09 10:28 PM
Rounded bolt, any help please? Brettus SV Talk, Tuning & Tweaking 14 27-10-08 10:45 PM
Rounded allen bolt svrob Bikes - Talk & Issues 11 05-07-08 07:09 AM
Rounded off screws... Mike1234 SV Talk, Tuning & Tweaking 6 06-11-06 11:36 PM
Rounded Screws Sudoxe SV Talk, Tuning & Tweaking 12 17-11-04 12:40 PM
