Old 13-07-08, 01:05 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default quick cam chain question
yes anther thread!!
a slight clicking / tapping noise has developed on the sv, has been like it for a roughly 3000 miles maybe more
now to me it sounds like the cam chain is slapping ever so slightly but i dont know anyone local with a curvy to compare it with and i forgot about it at AR
how hard is it to check, I've read the guide on the main site and the writer goes on about some special tool needed to retract the plunger
is it likely to be the cam chain or the valves?
help much appreciated
05 DRZ400E
RIP hovis
Old 13-07-08, 01:08 PM   #2
riktherider
Default Re: quick cam chain question
ive got the same problem too. need to fix it soon really. is it just at low revs and tickover?
Old 13-07-08, 02:59 PM   #3
Wideboy
Evel Knievel
Wideboy's Avatar
yeah, but not so much on tick over, usualy when you cruising between 3000 and 6000
05 DRZ400E
RIP hovis
Old 13-07-08, 03:01 PM   #4
Girth
Should of got a pointy......
Old 13-07-08, 04:04 PM   #5
husky03
take the top off of the tensioner and with a slim screw driver rewind it in, then let it pop back out-it might sort it, if it doesn't pop back out you'll know that the tensioners screwed-they can stick sometimes.
husky
Old 13-07-08, 11:02 PM   #6
Easier said than done, they're a bit of a git to get to.
Apparently, putting it in gear and rocking it backwards slightly can let the tensioner click out another notch. No idea whether it works or whether it's safe, though it does make sense.
They all make a bit of noise though, ljharmit had a video out at one point with what they sound like when they're about to go pop expensively. More of a "slapslapslap" than any tappety type noise. They need quite a bit of slack to jump teeth and hurt things!
Old 14-07-08, 07:39 AM   #7
empty
Empty's guide to looking at your cam chain tensioners....
http://forums.sv650.org/showpost.php...0&postcount=10
Except that it is a 5mm allen key rather than a 6mm.
MT
Old 14-07-08, 04:26 PM   #8
Wideboy
Evel Knievel
Wideboy's Avatar
what is the mileage that they usually go wrong? mines on at 13800, but i do occupationally give it some
EDIT: just seen ljharmit vid, mine is no where near as bad as that mine is just a light tappy click noise not a huge slap
05 DRZ400E
RIP hovis
Quick MOT question Ceri JC Bikes - Talk & Issues 4 26-08-08 05:19 PM
Quick Question Re Chain and Sprockets Spudsta71 SV Talk, Tuning & Tweaking 3 05-08-08 07:22 PM
Quick Question about Chain Tensile Strength bigE SV Talk, Tuning & Tweaking 1 24-09-06 11:40 PM
Quick Question, Quick Answer JakeRS SV Talk, Tuning & Tweaking 6 07-05-05 11:00 PM
quick question rednorvs Exhausts 10 10-04-05 07:44 PM
