Old 14-07-08, 12:23 PM   #1
monkeydispenser
Default Front wheel - scraping noise
Just recently everything seems to be going wrong!
At the moment if I push the bike along (which I do every morning out of the garage) I can hear a very slight scraping noise coming from the front wheel. To be honest, scraping makes it sound worse than it is since it's more a light rubbing, but with a slightly metallic edge to it.
Actually that description sounds even worse! It's been there since I bought the bike nearly a year ago and until recently I paid it no attention since noting else was wrong. But while I'm doing the fork seals (again) I thought I'd seek some knowledgeable advice.
Initially I thought it might be the brakes binding a little on the disc (it's that sort of noise), but I'd have thought it would make the discs red-hot after a ride, which they aren't. Possibly the wheel bearings?
Has anyone had a similar problem in the past, if it is a problem? Any tips for identifying just what it could be before I head to the Suzuki garage and end up with everything from the forks down being replaced at great expense!
Ta...
Old 14-07-08, 12:53 PM   #2
G
Default Re: Front wheel - scraping noise
will just be the pads very lightly rubbing on the discs, all bikes do it.
6.67300 × 10-11 m3 kg-1 s-2
Old 14-07-08, 01:07 PM   #3
monkeydispenser
Well thank L. Ron Hubbard for that!
So this is fine? You know, I was hoping it was all normal but I just thought I'd ask given the fact that loads of components seem to be wearing out at the moment!
Cheers...
Old 14-07-08, 01:10 PM   #4
G
99% sure, without hearing cant be 100%
But all bikes have a slight metalic rubbing sound when being pushed along.
Old 14-07-08, 01:29 PM   #5
Alpinestarhero
yea, theres a rubbing, my bike does it, the front and rear brake. Worse when the bike has been left out in the rain due to a nice coating of corrosion
but soon goes away.
So dont worry, your bike is fine
Old 14-07-08, 09:41 PM   #6
thefallenangel
but soon goes away.
+1
Old 14-07-08, 09:47 PM   #7
monkeydispenser
You've all made me feel much happier...Now if I can just sort out that fork seal leak and the nasty squeak I get when I pull away a little too fast I'll be ecstatic!
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
grinding noise from back wheel 650sx Pennine Massive 4 03-05-07 01:01 PM
front pads 'scraping' disc branny SV Talk, Tuning & Tweaking 5 19-05-06 01:34 PM
Hugger scraping the wheel? carty Bikes - Talk & Issues 1 12-04-06 01:59 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
