Old 17-07-08, 01:52 PM   #1
chakraist
Default Erratic speedo and tacho, engine very hot.
Right, I'm currently writing his from my phone whilst the bike is being serviced, but on the way down to the garage whilst running at high speed, the bike got very hot and started acting up, in that the speedo and rev counter started bouncing a little. It starts fine and still runs sweet, and the people at the garage are taking a look at the electrics as I'm guessing something has burned through when it was so hot. It was hit enough fir the oil to bubble a little anyways, the coolant might need topping up as it hadn't been something I'd checked. No other electrical issues except fir the dials, no loss of power or anything like that, starts fine and all idiot lights working. After I'd been riding slower with less revs it pretty much stopped and only bounced occasionally. Sound like an easy fix?
Old 17-07-08, 02:41 PM   #2
John Burt
Default Re: possible electric issue
Don't say which model you have but all curvys were prone to chaffing the loom in way of the seat bolts and the S is prone to corrosioj on th edash electrical connector inside the LHS upper fairing - both of these can give erratic speedo and revcounter readings
Old 17-07-08, 03:19 PM   #3
chakraist
Ah, thanks very much, just been serviced and seems all fine now, they couldn't see any issues with the wires. Yay!
Speedo & Tacho Dying Normski SV Talk, Tuning & Tweaking 5 23-07-08 11:15 AM
sv650s curvy- what are the light bulbs behind the speedo/tacho? vzzzbuxt SV Talk, Tuning & Tweaking 2 19-09-07 04:48 PM
Erratic Speedo? cowie SV Talk, Tuning & Tweaking 4 14-06-07 10:12 PM
Speedo Rotor & Engine coolant leak Nitzer SV Talk, Tuning & Tweaking 2 02-01-07 09:20 PM
Faulty/erratic speedo reading SV1000 ginger SV Talk, Tuning & Tweaking 5 03-05-05 10:05 AM
