Old 25-07-08, 12:51 PM   #1
BBadger
Default Help Please!
I was given a pair of oxford heated grips for my bday the other week ... yes heated grips in a realy hot summer.
At least their cheap at the moment though.
my main point was the wiring .... who has fitted these direct to the battery ( any issues or forgetting to turn off leaving a flat battery )??
or has any one wired them into the ignition relay , which i though would be clever as no flat battery ever or is this just more effort than its worth ??
thanks
Brock.
Old 25-07-08, 01:00 PM   #2
jambo
jambo's Avatar
Default Re: Help Please!
Take the time out to do it properly through a relay.
Direct to the battery has left me having to bump start my old Bandit 600 more than once. This may be because I left it on or someone else clicked it as they went past (less likely). Eitherway it doesn't matter how cold you are, you're too bloody warm after bumping a bike first thing on a cold day!
Taking the power directly through the ignition wiring isn't quite what I'd reccomend either as if there's a fault or they draw too much power and the wiring or fuse burns out your bike now doesn't run.
A relay lets you take power from the batery, and still stop it being enabled when the ignition is off.
HTH
Jambo
Old 25-07-08, 01:24 PM   #3
BBadger
hmmmmmmmmm i shull ponder on that one ... what about where the light connect
( also i have no clue about the wireing on this bike )
i had that though aswell what if some one just clicks it on, but the new one i have has the LED's so you should know.
where would be the best place to hook it up to.
dont worry i know you pain, ive bump started an ST4 now that was heavy, and didnt want to start.
Old 25-07-08, 01:28 PM   #4
K
Yeah - do it through a relay. A couple of bikes I've bought in teh past has had them direct to the battery - the first left me for dead at work one winter evenign when I'd left them on...
... the second had the battery whipped out and wiring checked as soon as I got it home and then promptly rewired the grips.
Old 25-07-08, 01:51 PM   #5
BBadger
Theres a simple way to do this.
let my dad, who bought them ..fit them
thatll teach him to skimp on presents =]
thanks for the help everyone.
the info has helped.
