Old 04-08-08, 11:39 AM   #1
Cam_73
Default Knocking noise
anyone able to shed any light on this one?
When pulling away in gear upto around 4000-4500 revs I get a bit of a knocking noise from the engine.
Seems to be gear/clutch related, as it doesn't appear if you open the throttle in neutral.
If you close the throttle or have it very skightly open, it doesn't happen.
Above 4500 rev's it doesn't seem to be there.
Any clue? Serviced a month or so back for 11k, now has 14k on the clock.
It's a SK3 pointy.
Old 04-08-08, 11:44 AM   #2
jambo
jambo's Avatar
Default Re: Knocking noise
Have you measured the slack in the chain at all points?
Old 04-08-08, 11:50 AM   #3
21QUEST
21QUEST's Avatar
Check your front sprocket......
Ben
Nemo me impune lacessit.
Old 04-08-08, 07:48 PM   #4
Cam_73
Checked chain after work.
35-40mm, bit slack from the 20-30mm in the manual.
That's doing 2000+ miles in two weeks I suppose.
Will check the sprocket too. Thanks chaps!
knocking noise thedon1000 SV Talk, Tuning & Tweaking 22 13-10-08 08:27 PM
Knocking noise @ chain? skyline SV Talk, Tuning & Tweaking 22 07-04-08 07:40 PM
Clicking Knocking Noise ? mattglavin SV Talk, Tuning & Tweaking 12 10-09-07 03:09 PM
Knocking noise in front fork k3lls SV Talk, Tuning & Tweaking 20 29-06-06 04:12 AM
knocking noise from front end dmracing SV Talk, Tuning & Tweaking 13 18-02-06 09:25 AM
