Old 06-08-08, 01:36 PM   #1
Nobbylad
Nobbylad's Avatar
Default Rear tyre damage?
Quickly checked over the tyres this morning before leaving for work. Rolled the bike forward from where it had been stood all night and on the rear tyre there was an area, just to the left side of the middle of the tread (if you're looking at the bike from the back) that looked almost as if it had been melted.
I checked over the rest of it and it looked OK and when I got to work I tried checking over again but couldn't see anything (dim light + no paddock stands etc).
Could it be that what I saw was just an imprint of where the tyre has been sat on the driveway over night? The bikes only 4 weeks old so I wouldn't have expected any damage just yet.
Old 06-08-08, 01:39 PM   #2
Default Re: Rear tyre damage?
it should be ok, i'd check your eyes again lol
Old 06-08-08, 02:16 PM   #3
punyXpress
punyXpress's Avatar
Was it wet when you parked it?
Then in the morning when you shifted it the bit that was on the ground would be the only wet bit ( as well as one at the front )
Old 06-08-08, 02:41 PM   #4
Nobbylad
Nobbylad's Avatar
When I parked it last night, it was raining and I just threw the cover over and left it.
This morning I rolled it forward and had a quick check of the tires, I told myself that the 'scarring' was probably just where it had been sat on the block paving (rough surface not smooth). Although it did look pretty deep i.e. at least 1mm so I wasn't sure if the weight of the bike would put an imprint in the tyre overnight and admittedly didn't see anything on the front tyre.
180 rear tyre 01 sv650s SV Talk, Tuning & Tweaking 9 30-10-08 11:12 AM
Rear tyre. LONGNECK650 SV Talk, Tuning & Tweaking 9 08-10-08 04:17 PM
Advice please- tyre damage DMC Bikes - Talk & Issues 9 21-07-08 11:03 AM
Tyre damage again !!! Question steveg SV Talk, Tuning & Tweaking 3 08-02-08 03:22 PM
Damage running deflated tyre Alpinestarhero Bikes - Talk & Issues 2 16-08-07 01:00 PM
