Old 06-08-08, 08:39 PM   #1
svrich
Default Concrete garage
Here goes the long shot...
Does anyone know the weight of a 16'x8' concrete sectional garage? I have sealed the deal on a second hand one but need to transport it from Norwich to Beccles (23 miles). I'm hoping to be able to hire a large trailer and tow it behind our Discovery but am unsure of the gross weight to be able to workout if I can do it.
Cheers.
Old 06-08-08, 08:42 PM   #2
Tim in Belgium
Default Re: Concrete garage
Do it in stages if the trailer tyres start to bulge?
What braked weight can the Disco haul, 3.5te?
Old 06-08-08, 09:03 PM   #3
svrich
I'm almost certain it can pull 3t but I've never done it before.
Old 06-08-08, 09:09 PM   #4
Troy
Don't know if this helps, but the average density of concrete is 2300 kg/m3
I bet if you call the company that makes them, they could tell you how much it weighs.
Old 06-08-08, 09:16 PM   #5
Tim in Belgium
Just take it steady then, I reckon it'll be under 3 tes probably. I've been in 4wds pulling 2te-4te of stone, low ratio may be required on steep uphills, and a lot of thinking about braking. Once off dual carriageways don't stray too much over 40 if the road bends.
Old 06-08-08, 09:53 PM   #6
punyXpress
punyXpress's Avatar
steep uphills
Are there any steep hills in that neck of the woods??
Old 06-08-08, 09:58 PM   #7
Tim in Belgium
Well just avoid the dikes!
Old 07-08-08, 06:50 AM   #8
Tris
PLUS ....
I've got a concrete garage and each of the panels are about 0.6 wide x 2.2 high x .05 thick (thickness is a complete guess as there is a thick bit around the edges and thin in the middle).
Given that the weight per panel would be 152kg (Make sure you take some BIG LADS with you to load the trailer)
Assuming there are 20 panels that gives you just over 3 tonnes plus all the bits like door, roof, trussess, etc
Good Luck and book the osteopath (sp) now
Old 07-08-08, 12:18 PM   #9
2mths
sounsd like two trips might be a lot easier and safer
Old 07-08-08, 07:54 PM   #10
svrich
Two trips it is then!
Finished the base today and am geting stupidy excited about the whole thing - my own little workshop for the first time ever
Your Garage!! rob13 Photos 172 05-11-07 09:05 PM
How to repair Asbestos Concrete Sheet roof 2mths Idle Banter 17 28-05-07 09:31 PM
Garage! rubberduckofdeath Idle Banter 33 17-04-07 09:54 PM
So I ought to be in the garage... northwind Idle Banter 24 08-01-07 08:33 AM
garage anna South & West Surfers 4 04-04-06 03:29 PM
