Old 20-08-08, 11:59 AM   #1
vardypeeps
Default SV650 99year (Curvy)
Hi Guy's
I know I'm new on here but was wondering if someone could inform me.
Just had my SV nearly 1 week now and when you blip the throttle (sat at lights) it can misfire now and again. Is this something I should really worry about or just a niggle that I will learn to put up with?
Thanks
Old 20-08-08, 12:03 PM   #2
Default Re: SV650 99year (Curvy)
your carbs need balancing
Old 20-08-08, 12:04 PM   #3
Grinch
Yep, sounds like it needs a balance... Either that you've had the jets done, put in a race filter and added a race can and the carbs are all mixed up now, so needs tuning in.
Old 20-08-08, 12:06 PM   #4
AndyBrad
where can u get a carb balancer?
Old 20-08-08, 12:07 PM   #5
vardypeeps
Cheers. I think it's only the can which has been changed to a Viper one.
Quick question I have a set of gauges and a haynes but can you point me in the right direction of which parts I will need to take off etc to get to the carb spigot thingys
Old 20-08-08, 12:10 PM   #6
vardypeeps
Andy if you jump online you can get hold of them pritty easy and good ones at that. Also you could pop to a few bike shops they usually have them in. It's worth doing yourself saves about £45/£50 a time.
A fellow Brighouse Lad!!! Small world
Question still stands on the carb spigots etc
Old 20-08-08, 12:16 PM   #7
Grinch
Carbtune sell them direct for about 50quid... which is about what they sell on ebay for.
Old 20-08-08, 03:35 PM   #8
jambo
jambo's Avatar
The rear spigot is easy, just follow the vacuum line from the fuel tank to the rear carb base, take it off and plug in there.
The front is slightly more involved. It's right at the front of the carb blanked off with a rubber plug, if you get a torch, and squint, and point it up behind the rad to the back of the front cylinder then go up a bit to the carb you should see it but it's a complete pain to get to. Get some 6mm rubber piping and connect it on there and leave a length hanging down, blanked off for easy access next time. I had the carbs off when I was looking for mine so I added the tube then.
Jambo
My 2nd SV650 curvy richspace Idle Banter 4 08-03-09 01:04 PM
sv650 '99 curvy - naked and fun!!! mikeSV For Sale - SV's and SV related items 2 29-06-08 12:17 PM
SV650 Curvy carsounds_dan Stuff Wanted 4 04-04-08 07:21 PM
sv650 curvy ICAEW For Sale - SV's and SV related items 0 03-03-08 10:28 AM
Best can for 99 curvy sv650?? 5v5 rider SV Talk, Tuning & Tweaking 14 09-05-06 04:56 PM
