Old 24-08-08, 06:45 AM   #1
stephen365
Default Fitting Decals
I've bought a set of Decals for the curvy SV650. It's had a custom paint job, so the previous ones were removed. Anyone any pointers?
Does it need any prep beforehand and are there any tips for smoothing out the air from the sticker?
Also, does anyone know of anywhere where I can find detailed measurements for placement?
Ta
Steve
Old 24-08-08, 07:40 AM   #2
Paul the 6th
Paul the 6th's Avatar
Default Re: Fitting Decals
Mornin!
This might help
Asside from the above, water with a tiny bit of washing up liquid mixed in (as an application fluid) will make getting the bubbles out a lot easier. As you press the water out, the adhesive makes contact and sticks. Any remaining bubbles can escape since they're actually water bubbles and can slide between the adhesive and plastics.
In terms of placement, have a look at a mates bike or on the net to get a rough idea of where they should be, and then line them up where you think it looks best?
Hope this helps
edit: oh and squeeze the bubbles from the centre outwards, then any creases will be pushed to the edge and disappear.
Where to put decals? dirtsk8 Photos 0 20-07-08 07:15 PM
Decals John 675 Photos 8 25-02-08 07:20 AM
SV Decals - However you like em The Mass SV Talk, Tuning & Tweaking 11 23-01-06 09:48 PM
sv decals?? riktherider SV Talk, Tuning & Tweaking 8 07-06-05 07:35 PM
Decals gc350 SV Talk, Tuning & Tweaking 1 18-05-05 05:13 PM
