Old 26-08-08, 11:23 AM   #1
Caddy2000
Default Windows XP 32 or 64 bit?
Wassa difference?
Looking to reinstall XP on to my Dell computer (wipe C drive and start from scratch), as I want to get rid of all the dell software on it that seems to be conflicting with my network, and also causing BSOD
For my level of computing I get on with XP and can get it cheap, but which should I get? And what is the difference?
Oh, I'm working with
2x 3ghz Pentium D's
2 GB Ram
GeForce somethingorother
And there is a motherboard (whatever Dell fitted)
Old 26-08-08, 11:30 AM   #2
Grinch
Default Re: Windows XP 32 or 64 bit?
Well your need a 64bit system to support the 64bit operating system. So unless it says '64bit' somewhere like on the box or in the manual you won't be able to run 64bit XP.
Old 26-08-08, 11:30 AM   #3
600+
I would go with 32bit cause if u go for the 64bit you will need to find drivers for that.....and it can be a pain.
Difference between the 32 and 64bit depends on your processor (whether it is a 32 or 64bit one) i.e. if it can process 32bit string or 64
Old 26-08-08, 11:39 AM   #4
ThEGr33k
I agree. 32 is proven and works. 64 is still buggy.
Old 26-08-08, 11:41 AM   #5
Filipe M.
The PentiumD 3.0 will support 64 bit, but like others said, driver search can be a pain. Also some software might refuse to run under the x86 32bit emulation thingy, so you'll be screwed if that happens. On the other hand, I've found the 64 bit version to be ever so slightly more robust than the 32 bit one...
Old 26-08-08, 11:52 AM   #6
jimmy__riddle
64 bit is not buggy, runs better than 32 bit IMO, drivers are not too much of a pain depending on what you use the PC for, big companies like logitech etc are god at providing 64 bit drivers. do a search first and check for drivers before you decide. Oh, and havn't had anywhere new as much spyware and viruses on xp64.
Old 26-08-08, 11:58 AM   #7
Caddy2000
Sounds like 32 bit is the way forward!
Cheers all you lovely people!
Old 26-08-08, 11:58 AM   #8
Grinch
If you feeling really fancy you could 'dual' boot it and see how you like it.
Old 26-08-08, 12:03 PM   #9
Caddy2000
Just trying to think about that has made my head BSOD!!!
Tinted Windows Alpinestarhero Idle Banter 17 24-04-08 10:48 AM
Windows 7 gettin2dizzy Idle Banter 15 09-04-08 12:27 PM
How to clean windows? tigersaw Idle Banter 22 17-03-07 08:34 AM
New Windows Law Idle Banter 61 01-02-07 11:53 PM
windows question timwilky Idle Banter 8 21-02-06 06:06 PM
