Old 26-08-08, 06:16 PM   #1
Ben Flanagan
Default Not starting
My 00 SV650s wont start on the button. If I bridge the starter solenoid it starts fine. If I take out the relay and give it a feed it clicks so that seems fine. The side stand has been sniped but the 2 wires are bridged so thats ok too. I checked all the multi plugs around the clocks for corosion but theres none and the neutral wire from the gear box seems ok too. I didnt test any of the wires for continuity but theres no sign of damage to any of the looms. I opened the actual switch and had a look and the contacts seem ok. Any ideas anybody???
Old 26-08-08, 10:54 PM   #2
ridelikeaturtle
Default Re: Not starting
-- neutral safety switch at the clutch lever?
-- battery cable?
-- fuses?
Old 26-08-08, 11:26 PM   #3
ethariel
ethariel's Avatar
Kill switch?
ethariel is offline   Reply With Quote
Old 27-08-08, 07:50 AM   #4
boo86
clutch switch ? I've by passed all my nuetral safety switches and key ignition( The ignition now works from the kill switch)
Trace the clutch switch back to the yellow mukti plug and brigde it by pulling the 2 wires out and soldering them up stream of the multi plug. that way if any os your switchs fail your bike will still work. You can actualy trace the side stand switch all the way back to beside the rear coil and bridge there. It's much neater.
Old 27-08-08, 07:57 AM   #5
Grinch
I take it you get lights on the dash?
help with starting - YC scottjames SV Talk, Tuning & Tweaking 20 10-10-10 04:51 PM
Wow - Just starting out Grinch Idle Banter 38 29-11-07 06:05 PM
SV not starting Draper SV Talk, Tuning & Tweaking 21 27-09-07 02:20 PM
Help starting up Spewy SV Talk, Tuning & Tweaking 8 03-04-06 12:07 PM
Starting to look better !! Supervox Photos 9 03-09-05 02:41 PM
