Old 29-08-08, 08:14 AM   #1
olden mgroin
Default noisy chain
mornin all, yesterday i fitted a 47t rear sprocket and new chain, first of all it has made a difference to accelaration (pulls off quicker) although the bike does rev slightly higher than normal, the thing thats bothering me is that i decided to go for a heavier chain than standard, now when i apply the throttle i can hear a noise that was'nt there before, i'm hoping it's just the sound of the heavier chain. has anyone else had this noise or should i go back to standard chain?
ANY IDEAS PLEASE!
Old 29-08-08, 12:05 PM   #2
vardypeeps
Default Re: noisy chain
You tend to get more chain noise when a new one is fitted and at the right tightness. Just make sure that it aint too tight or too loose thats the main thing.
Old 29-08-08, 12:23 PM   #3
jambo
jambo's Avatar
Hi,
When you say you've gone for a heavier chain, I assume you're still on a 525 pitch chain, just a different manufacturer and spec? Make sure it's well oiled (being new, should be fine, but will be greased not oiled, no idea if that'll make a difference). Have you checked the front sprocket is OK?
Jambo
Edit: Also, as vardy points out, check chain tension
Old 29-08-08, 12:26 PM   #4
vardypeeps
What he said
Old 30-08-08, 06:27 AM   #5
shelleyamy
Could it be that you haven't aligned the rear wheel, making the chain/rear sprocket slightly "twisted" ?
Mike
Old 30-08-08, 10:20 AM   #6
Dangerous Dave
Check it is lubed and aligned correctly.
Old 30-08-08, 11:32 AM   #7
olden mgroin
thanks for all your replies, i've altered tension slightly and lubed it more, noise still there but not as much, i think it 's just the fact the chain is heavier.
Old 30-08-08, 11:59 AM   #8
ThEGr33k
Probably needs running in a little. Did you change both sprockets? And why did you go for a heavier chain anyway?
Noisy Chain startrek.steve SV Talk, Tuning & Tweaking 12 18-08-09 11:51 AM
Noisy chain? Phaelok SV Talk, Tuning & Tweaking 6 14-10-08 09:25 PM
How *noisy* is this bike supposed to be.... mattb200 Bikes - Talk & Issues 27 10-03-08 06:23 PM
Noisy bike, coolant low? TheStudent SV Talk, Tuning & Tweaking 5 09-02-08 09:31 PM
Noisy K3 lukemillar SV Talk, Tuning & Tweaking 4 25-09-06 07:47 PM
