Hi all, just wondered those of you who do it yourselves, what type & make of guages/columns do you use/prefer, I'm thinking of getting a set, but I'm not sure which might be the best..... there seem s to be a lot of dial-type ones around, but I'm used to using me mates mercury columns, which have a much larger scale for more accurate fine-tuning......sadly he works abroad a lot now or I'd continue to use them.....
I once read an article on the ZZ-R international forum explaining how to make a set, I'll try to find it & post it on here if I do.... Cheers |
I think this is one of the areas where you basically get what you pay for. Unless you want to make your own guages then buy the best that you can afford normally Carbtune or Davida. Don't think theres much difference between dials and column types apart from maybe columns being easier to read. I've heard that cheap guages can lack accuracy which is obviously not good.
I've got a set of Carbtune guages that I've had for years. They've paid for themselves many many times over and I would buy them again in a shot. |
I personally use a Carbtune but I have been told the Accumate one is good to.
I've got the morgan carbtunes, you can make a mercury or oil based manometer, but not so durable. Drop me a PM and you can come round and use mine.
#5 | |
![]() ![]() Last edited by Blue_SV650S; 31-08-08 at 01:39 PM. |
Mine are fine, the capillary damping tubes are a tight fit.
Thanks for your advice everyone, and yorkie Chris, thanks for the kind offer... I'll PM you when I'm ready to do them..cheers
![]() John |
I made an electronic one, using a differential pressure transducer (rs components). It does suffer a little drift so it is necessary to check back to "zero" it occasionally. I'm sure an electronics expert could stabilise it, I live with the drift.
Also, as with any method using two scales, it's a good idea to swap the connections over to confirm you get the same readings the other way round when you've finished adjusting. Cheap dial gauges are often troublesome. Carbtunes seem to be a good compromise of cost/effectiveness.
#9 |
how to make a homemade manometer........
http:www.powerchutes.com/manometer.asp I'll knock one up and see how it goes............................. ![]() |
#10 |
I've got Davida balancers....the rubber hoses came in rather handy once as an emergency....lol. They do the job fine
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
K2 Naked - carburettor O rings? | ejohnh | SV Talk, Tuning & Tweaking | 3 | 27-12-06 10:41 AM |
Rear Carburettor Choke Plunger Screw | fizzwheel | SV Talk, Tuning & Tweaking | 8 | 09-04-06 07:51 PM |
Scottoiler/engine vaccum query | Ceri JC | SV Talk, Tuning & Tweaking | 3 | 11-02-06 01:19 PM |
carburettor parts - info about similarities | wreckah | SV Talk, Tuning & Tweaking | 1 | 20-12-05 04:18 AM |
wanted: curvy carburettor slides, or complete carb setup | wreckah | Stuff Wanted | 0 | 10-12-05 10:01 AM |
