Old 01-09-08, 04:36 PM   #1
ihitge
Default Won't start
Hi All,
I dropped my bike in a controlled manner on the left side today. Barely touched the ground but now the bike won't start. Lights go on so I don't think it is anything battery related. Tried to push start it but no luck.
Any suggestions?
Many Thanks,
Ihitge
Old 01-09-08, 04:40 PM   #2
Alpinestarhero
Default Re: Won't start
Check the side-stand switch, and also the clutch switch, they might have got bent or something like that?
Matt
Old 01-09-08, 04:55 PM   #3
ihitge
Thanks - I checked the stand switch, seems to be fine. Where is the clutch switch situated?
Old 01-09-08, 04:57 PM   #4
Dangerous Dave
Under the clutch lever on the perch, it is a small black connector which runs from the switch gear to two pins on the clutch perch.
The picture below is not a SV but you should get the idea...
Old 01-09-08, 05:10 PM   #5
ihitge
Thanks Dave - I checked it and everything seems to be intact.
Old 01-09-08, 05:27 PM   #6
metalmonkey
Is this an injected or carbed bike? A bit more info would be useful, also what you have checked ect.
Old 01-09-08, 06:06 PM   #7
Woz
Sounds daft (but nearly everyone has done it), have you knocked the kill switch when picking the bike up?
Old 01-09-08, 06:50 PM   #8
Tallguy
Tallguy's Avatar
Lightbulb Re: Won't start
I was going to post exactly the same thing.
I almost dropped my RVF400 onto it's left side some years back, then spent a frantic hour trying everything (sidestand switch, bump starting, working through the alarm/immobiliser possibilities etc).
I must've knocked the kill switch ever so slightly whilst grappling with the bars to not let her fall over; the switch LOOKED like it was fully "on" but it was not quite flat against the stop - obviously just enough to prevent any ignition and enhance my embarrassment.
After rocking the switch to fully off, on, off then on again, the magic happened and the V4 came back to life.
Needless to say, I felt very silly. Just as well no one was around!
So, after all that, I hope it's that simple. It didn't occur to me initially to look for things on the right side of the bike 'cos the drop was to the left.
If it's not then I'm sure one of our esteemed experts in the .org will be able to explore other possibilities.
p.s. Separate issue: Can you imagine me, 6ft5in, riding an RVF400? I never needed to lock it, I could just pick it up & put it in my pocket after arriving at my destination...
Pointy K3S in SuperSonicSilver, R&G bungs, Carbon Can Co slip-on SOLD TO MEMBER "Cobra"! So long old friend!
I'm going all Charley Boorman on yo' ass. Can't filter or indicate any more.
Tallguy is offline   Reply With Quote
Old 01-09-08, 09:28 PM   #9
ihitge
It is sorted! Had to over ride the clutch kill switch with a hairpin.
Thanks for all your help and quick responses.
A sad start to the day ooger Idle Banter 17 03-06-08 11:27 AM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
She won't start! Help! Bear SV Talk, Tuning & Tweaking 43 19-12-06 11:39 AM
yet another won't start, 01 650 mann650 SV Talk, Tuning & Tweaking 4 25-07-06 03:54 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
