Old 02-09-08, 01:43 PM   #1
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Mechanics?
Righto, a friend of mine has recently done a complete strip of his triumph trophy engine, just been looking at the bits and noticed something i've never seen before
imagine the cog on the end of the balancer shaft, it's about 12mm wide. now immediately next to it, touching, is a cog of the same diameter, only about 4mm wide or so, but here's the kicker, there's fewer teeth on this cog than the larger one so if you turn the shaft the two sets of teeth go in and out of phase
but it gets better... the smaller width cog is on the inside of the larger width one from the point of view of the assembled engine, but it isn't actually connected to the balancer shaft, it's free to rotate around it
can someone please enlighten me as to what this arrangement of cogs is called and what purpose it serves, there was another one on the sprag clutch
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 02-09-08, 02:04 PM   #2
Default Re: Mechanics???
Some type of accessory drive?
Can you get a pic, as I'm not entirely sure what you're on about
Old 02-09-08, 02:08 PM   #3
the_lone_wolf
Captain Awesome
yeah i know, it's hard to describe, haven't got a camera but as i'm not busy i'll knock something up in autocad and create a model
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 02-09-08, 02:28 PM   #4
the_lone_wolf
Captain Awesome
image uploaded:
the larger cog is connected to the shaft, the smaller one rotates freely around it - if you look at the teeth you'll see the smaller cog has fewer so they go out of phase as you spin the shaft
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 02-09-08, 02:37 PM   #5
Tis to eliminate backlash and chatter
Old 02-09-08, 02:41 PM   #6
Alpinestarhero
Interesting....can you explain it a bit more for me YC? I havn't seen anything like this before
Old 02-09-08, 02:50 PM   #7
the_lone_wolf
Captain Awesome
oi, who moved my thread
i'd imagine because the tooth on the crackshaft cog has to slightly prise apart the two cogs it might help them mate better
do you know what it's called chris?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 02-09-08, 03:29 PM   #8
Seen them before on CNC machines, normally have equal number of teeth with springs to push them half a tooth apart, takes up the play between the gears.
I imagine the friction between the 2 (as small gear is rotating faster) will damp down gear noise.
Listen to a car in reverse to hear why you need to damp down the noise of straight cut gears.
Any car mechanics out there? flymo Idle Banter 10 01-02-09 01:03 AM
Any car mechanics here? StreetHawk Idle Banter 13 19-08-08 11:42 AM
SV Mechanics - Michigan pilot SV Talk, Tuning & Tweaking 2 06-08-08 08:20 PM
Cardiff Mechanics Rhiwbina_Squirrel South & West Surfers 6 04-04-08 11:39 PM
My first go at motorbike mechanics Ryest Bikes - Talk & Issues 13 05-11-07 08:36 PM
