Old 02-09-08, 08:48 PM   #1
stnd
Default Valve Clearance Tight
I recently put my front cylinder together and one of the exhaust valves has no clearance, I put a 135 shim in because that is all I had at the moment and still no clearance.
I am wondering how fast do valves burn out due to no clearance, if I need to ride 10km / day over the next week until I can get some smaller shims will the valve burn or melt.
thanks.
Old 02-09-08, 09:01 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Valve Clearance Tight
No clearance means the valve wont shut properly so I think you risk burning it out quite quickly.Id fix it before using it.
Old 02-09-08, 10:52 PM   #3
embee
embee's Avatar
Originally Posted by stnd View Post
I......one of the exhaust valves has no clearance,.... *if I need to ride 10km / day over the next week until I can get some smaller shims **will the valve burn or melt.
*Don't.
**Yes it will....and probably lead to pre-ignition which will see off the piston too.
Valve Clearance Readings Mr_Chin SV Talk, Tuning & Tweaking 2 22-12-08 08:54 AM
Valve clearance checking. Mark_h SV Talk, Tuning & Tweaking 6 22-12-08 08:31 AM
A question of valve clearance... BillyC SV Talk, Tuning & Tweaking 11 23-11-05 12:36 AM
15k service - valve clearance The Mass SV Talk, Tuning & Tweaking 21 18-08-05 09:41 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
