Old 10-09-08, 09:35 PM   #1
tonny006
Default Timing Retard Eliminator. Do They Work?
i have just found this on ebay.
Has anyone used one?
http://cgi.ebay.co.uk/TRE-for-SV650-...d=p3286.c0.m14
Old 10-09-08, 09:41 PM   #2
xXBADGERXx
Default Re: Timing Retard Eliminator. Do They Work?
Don`t bother , the SV has very little Retarding on it , unless you count me on a bike
Old 10-09-08, 09:43 PM   #3
Mr Speirs
Mr Speirs's Avatar
Is this an old post just copied and pasted?
Yes they eliminate the Timing Retard but some people contest that the real world benefits are negligible. Also you can do it for free using nothing more than a small screwdriver and tweezers or a pair of snips.
If you do a search for TRE it will lead you to a good step by step guide to getting the same effect for nothing.
I have done it myself but haven't noticed a marked difference in performance but like the knowledge of knowing each gear is being fuelled properly
Old 10-09-08, 10:01 PM   #4
simesb
Has anyone actually tested it in an empirical fashion? Most folk say it's not worth doing, but some seem to swear by it.
Old 10-09-08, 10:08 PM   #5
Mr Speirs
Mr Speirs's Avatar
One fella on a previous TRE do they work post actually dyno tested an SV650 with and without the mod and test revealed that it made no difference whatsoever.
Old 10-09-08, 10:18 PM   #6
It wouldn't suprise me if it were zadar... and no... the TRE's make such a small difference it isn't really a performance item, certainly not worth the money the pre-built TRE's are sold for.
Old 10-09-08, 10:24 PM   #7
xXBADGERXx
It`s a perception thing , people swear it makes a difference as they tear open the throttle to "test" it , in reality , it makes little to no difference , save the money and spend 30 quid on a useful item like an oil rad guard or Fenda Extenda
Old 10-09-08, 10:25 PM   #8
Or even do it... but for f###s sake do it properly with a resistor worth about 6p for the same effect...
Old 10-09-08, 10:28 PM   #9
xXBADGERXx
There is that too
Old 11-09-08, 08:20 AM   #10
boo86
you can do it for free ( i have on mine) cut the wires coming out of the gear possition indicator. only the green and red, the others are for the nuetral light. Then the bike doesn't know what gear it's in and therefore cant retard the timing in 2nd and 3rd.
see http://www.sv650.org/ig_retard/ignition_mod.htm
TRE - Timing Retard Eliminator tone64 SV Talk, Tuning & Tweaking 6 13-07-08 08:31 PM
TRE-Timing Retard Eliminator slydog SV Talk, Tuning & Tweaking 12 30-04-08 07:49 PM
Timing Retard Eliminator carlSV For Sale - SV's and SV related items 0 03-09-06 06:39 PM
Timing Retard Eliminator (TRE).......... DanAbnormal SV Talk, Tuning & Tweaking 2 06-07-06 08:44 AM
D.I.Y timing retard eliminator. HELP !!!!!!!!! RayCav SV Talk, Tuning & Tweaking 7 26-02-06 02:39 PM
