Old 14-09-08, 07:50 PM   #1
DF!
Default LED Flash rate relays...
After fitting my new LED tips, the rear LHS indicator seems to have packed up. I have a similar looking flash rate relay / resistor thingy to this:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2759.l1259
Seems cheap enough, does anyone know if they would work / have similar on theirs?
Old 14-09-08, 08:20 PM   #2
Aiki
Default Re: LED Flash rate relays...
they're just resistors, plug em in in parallel to your indicators and bobs your mother brother, although they seem a mite expensive for a couple of 5ohm resistors.
Old 14-09-08, 08:29 PM   #3
DF!
so could i get a 5 ohm resistor from maplin perhaps?
Does it need to be 12v?
Old 17-09-08, 06:43 AM   #4
Heed
The voltage doesn't matter for a resistor. However the current rating does. I got a set of 2 from eBay for around 6 quid and they've been doing the trick for over a year now.
Old 17-09-08, 06:47 AM   #5
SoulKiss
SoulKiss's Avatar
Always use a relay
Resistors are just bodges.
Not the normal type of indicator flash rate problem.... DarrenSV650S SV Talk, Tuning & Tweaking 11 03-07-08 06:42 PM
LED indicators and flash rate Quiff Wichard Bikes - Talk & Issues 12 28-05-06 11:09 AM
Led indicator flash rate TC3 SV Talk, Tuning & Tweaking 16 11-12-05 08:15 AM
LED Indicators - Flash Rate mastiffmat SV Talk, Tuning & Tweaking 3 09-11-05 04:54 PM
Flash rate Problems?? (Non LED) Sledgehammer SV Talk, Tuning & Tweaking 7 15-08-05 08:45 PM
