Old 28-09-08, 11:51 AM   #1
BBadger
Default Off on friday night =[
Woke up in a ditch on Downside road in cobham. around 10 something.
there was sand and all maner of **** on the road so i think i must of hit that. still managed to pull my bike out of a 6 ft ditch with a broken legg.
All i can say is thank god for the council chopping down trees, i landed behind a big stump.
O also any help on bits that i need would be much aprreciated
- radiator
-gear change
- bars
( not sure if the rod that goes from the gear change to the gear box is a little bend ...... is it fatal or fixable at a cost ? )
brock.
Old 28-09-08, 12:09 PM   #2
Baph
Default Re: Off on friday night =[
Ouch GWS matey.
If by that you mean the push-rod (at the back of the worm drive), and is part of the clutch, not the gear change. You can just pull this out & replace it easily.
Same goes if you mean the gear link rod (connects the gear lever to the rotating shaft that comes out of the gearbox). Only here it needs unbolting.
If you mean the rotating shaft itself (moved by the link rod), then I'm not sure exactly how you'd get at that, but from the parts fische, it's 25510-19F00, and looks like it'll slide out no problems, without having to strip the gearbox. You might need associated washers/springs etc.
Old 28-09-08, 12:12 PM   #3
Dangerous Dave
Get well soon mate....
Old 28-09-08, 01:35 PM   #4
BBadger
Cheers guys.
and thansk Baph, it all looks ok atm, and the link rod is bent but my worry was about the rotating shaft, but again it looks to be good.
thanks
brock.
Old 28-09-08, 01:53 PM   #5
BBadger
O could any one tell me if the radiator for a curvy is the same for a pointy ??
Old 28-09-08, 01:54 PM   #6
Sorry to hear dude.
If shift-shaft is bent then you remove RHS cover, clutch, undo circlip on end, remove clutch and slide out. Not as hard as it sounds but iirc you do need to drop oil out.
Search for a thread by silent11 on the matter, he bent one, it showed as not returning properly in between shifts. Curvy one fits pointy too, but I've not more spares.
Radiators are not interchangeable AFAIK
Old 28-09-08, 02:09 PM   #7
BBadger
I shull get onto that, not to sure if its bent or not =/.
Go look at a bowl of fruit, my radiator could replace the bannana atm its that bent ( not leaked though so it holding up ok. )
Any idea how much a new one would cost ??
thanks
brock.
Old 28-09-08, 02:55 PM   #8
A f###ing lot. Go secondhand, or maybe try a repair.
Old 28-09-08, 04:01 PM   #9
joshmac
Sorry to hear about your off Brock, GWS
Old 28-09-08, 04:03 PM   #10
tanis34
ouch gws m8 and i hope the bike fixes quickly aswell
Friday night is upon us once again... Jdubya The Essex Lounge 18 24-06-06 08:19 AM
Friday night ArtyLady The Essex Lounge 33 17-06-06 01:17 PM
So what are you doing on friday night? Jdubya The Essex Lounge 6 31-03-06 06:49 PM
Friday Night Supervox The Essex Lounge 13 24-06-05 06:00 PM
