Old 28-09-08, 08:55 PM   #1
Irksy
Default Time for a Suspension Upgrade!
Hi folks Noob in Need here!
Apologies in advance as i will either; a -be asking stupid questions
b -not put any relevant info in
or c -be wasting everyones time including my own
Now I know this subject will of been covered but after searching thru the forum for a couple of hours i still couldn't find the correct info.
I currently have a standard 2001 650s Curvy and am looking to upgrade the front forks and have happened upon a full set of GSXR600 fork internals (my uncle has upgraded his track day bike and has a set lying around).
To start with will these fit? And being a noob will only a small amount of technical knowledge how should i go about fitting them?
All help most graciously received!
Old 28-09-08, 09:46 PM   #2
Default Re: Time for a Suspension Upgrade!
hi, if its just internals .. no. if its the whole forks then yes.
but you will need the yokes as well, also the top bearing is different.
but someone with more knowledge will be along soon.
Old 28-09-08, 11:34 PM   #3
independentphoto
"internals - no"
+1
Old 28-09-08, 11:38 PM   #4
Says who. Has anyone done it? Tried it? Failed?
I've heard of VTR firestorm cartridges being fitted. However the SRAD forks are a f### site bigger than the SV ones... dunno what model you have but the forks are all bigger diameter than the SV.
I agree that it's easier to fit the whole front end, probably. Maybe. But I wouldn't write it off as impossible.
Old 29-09-08, 12:30 AM   #5
chakraist
You could probably sell the internals you have and get some decent springs which would fit (or fit easier)?
Old 29-09-08, 03:09 AM   #6
Irksy
Whats the diameter of the sv springs? Anyone know?
Old 29-09-08, 07:53 AM   #7
erik
from my 1999 sv650s:
OD = 35.2mm
ID = 25.4mm
Old 29-09-08, 11:54 AM   #8
Dangerous Dave
I don't think the GSXR internals will fit in the SV forks.
There are a few ways to improve the SV's front end;
- Progressive/Linear Springs and oil to suit you weight
- Race Tech Fork Emulators
- A full GSXR front end
Old 29-09-08, 12:22 PM   #9
Irksy
Just been looking at an american site with racetech springs and the sizes it quotes are ; SV650s 99-08 Spring Dimensions 34.7mm x 340mm
GSXR600 06-07 Spring Dimensions 35.5mm x 33.5mm x 270mm
First question, why the extra measurement? (probably being a complete tool here) and secondly I am hoping there is a tiny bit of leeway with the diameter or if not can i make some leeway with a sledgehammer?
Old 29-09-08, 12:23 PM   #10
Why are you looking at spring sizes? Are you wanting to fit the springs, or the cartridges?
Suspension Upgrade makemdan SV Talk, Tuning & Tweaking 8 04-02-08 09:06 PM
Suspension Upgrade Cam_73 SV Ecosse 4 08-11-07 02:11 AM
which is best suspension upgrade gazza SV Talk, Tuning & Tweaking 12 01-11-07 05:34 PM
Suspension Upgrade svdemon SV Talk, Tuning & Tweaking 3 18-08-07 02:15 PM
Suspension upgrade MattTheLoony SV Talk, Tuning & Tweaking 9 09-06-06 11:30 AM
