Old 12-10-08, 04:09 PM   #1
vardypeeps
Default Cutting Out 99 SV650s (Curvy)
Right'o I need to get to the bottom of this problem. Not sure if it was due to spirited riding on Sunday Ride Out but my bike cuts out on me now and again.
Could everyone give me there suggestions of what it could be.
Basically bike will be running fine and the all power goes lights, engine everything. It does not seem to do it at specific time either (like when I use my indicators etc).
I just need suggestions other than wiring loom as I'm sure I have found all the faults on that.
Thanks Guy's n Gal's
Old 13-10-08, 07:14 AM   #2
Dangerous Dave
Default Re: Cutting Out 99 SV650s (Curvy)
Check all the wiring around the headstock for chaffing.
Old 13-10-08, 09:49 AM   #3
vardypeeps
Could it be anything else? I have checked around the headstock twice now
Old 13-10-08, 09:53 AM   #4
Alpinestarhero
Check for damp in the connections? There are some chaffing points around the rear subframe aswell
Old 13-10-08, 09:56 AM   #5
vardypeeps
Yeah I managed to find a broken connection where the loom goes to the fuse box. That fixed my dip beam head lights so there working now but I have checked the rest of the loom
I Found that my cooling fan wires had rubbed through also but I have now taped that up. It might need a closer inspection. Only other thing I can think of is it's overheating maybe???
Could there be a problem with battery or altenator etc?
Old 13-10-08, 10:05 AM   #6
you did have a spaghetti western going on in the back of your tail pod..lol. When you waggled that lot, the lights came back on, I think summats loose up there or chaffed.
Now where to start with mine. It blows fuses now its had an engine swap, at any time no particular thing happens, everything just goes off, though we'd fixed it but obviously not
.but where to start??
Old 13-10-08, 10:07 AM   #7
Alpinestarhero
With the cooling fan connection, sort that out quick...I find my curvy dosnt overheat enough to cause the fan to some on except when I am really stuck in traffic, but you do need it! Could be shorting out something?
Could be something getting hot and the expansion causing a disconnection, although thats probably a far fetched idea
Old 13-10-08, 10:10 AM   #8
Robs bike cut out whilst riding it, I've not seen that before. Most inoportune moment up a hill in busy slow traffic
Old 13-10-08, 10:13 AM   #9
vardypeeps
Yeah I was thinking that too. I will check out the wiring in the back of my tail pod and see if that sorts it. It's so strange as it does not seem to do it at a certain moment and I have checked all the loom before. I will take a second look see if there is anything I missed. Your problem sounds a bit like mine that I had with my head lights. One of the wires was earthing on the frame as the insulation had been rubbed through thus blowing fuses all the time. After I taped up the wire it was fine
Any way if you think you find your problem let me know as well and I will check on my bike
So Confusing
Old 13-10-08, 10:18 AM   #10
simesb
+1 - and break open the connectors to see signs of arcing.
SV650S K2 Last of the Curvy! GAZER For Sale - SV's and SV related items 3 07-06-08 08:18 PM
Curvy SV650S For Sale Marshall For Sale - SV's and SV related items 25 17-02-07 10:15 PM
Cutting point for Renegade standard level on a Curvy ['01] SV650S_DUB SV Talk, Tuning & Tweaking 2 29-03-06 06:34 PM
Cutting lowers on a Curvy? kinesin SV Talk, Tuning & Tweaking 3 08-02-06 12:18 AM
R&Gs For Curvy (K2 SV650S) - No Fairing Cutting Required exduker Ancillaries 0 22-08-05 09:51 AM
